Online Now [465]:
Visitors: 465
Today: 173980
Total: 151950684
Forums › The Car › 206 Problems › broken crown wheel
broken crown wheel
PostPosted: Fri Feb 01, 2013 4:38 pm Up
any idea what's the cause of that?
PostPosted: Fri Feb 01, 2013 5:05 pm Up
In the photo it is difficult to see but are the breaks, or the most recent part of it thinner than the metal on adjacent teeth.
Were there any symptoms leading up to the failure?
Is there wear on adjacent teeth and is that wear only on a section of the crown wheel as that could be worn / seized or partially seized bearing.
I have seen similar; boy racer doing a tyre spin pull away. Just as the car started to move off it dropped into quite a big pot hole. The resultant jolt sheared the teeth. The boy racer was my brother in a Vauxhall Viva.
Rob2859
PostPosted: Fri Feb 01, 2013 8:14 pm Up
Strange, I know the crown had a tenancy to drop out but not heard of that one. Wheel spinning while the wheel is turned generally shags the planet gears but not sure if it could cause damage to the crown.
Excessive play in the bearings could stress it. Lack of lubrication could play a part. Not sure how else it could be overloaded.
PostPosted: Sat Feb 02, 2013 5:33 am Up
no ideal at all, that is my mate's gearbox. I think the crown wheel teeth broke during the rally event at speed Shocked
wasn't too powerful either. stock 1.6 16v with kent cam
PostPosted: Sat Feb 02, 2013 10:23 am Up
Clasic down-shift mashup by the looks of it.
PostPosted: Sat Feb 02, 2013 4:08 pm Up
wasn't shifting when it broke.
we though it might be the poor quality of the crown wheel
