Posted: Fri Feb 01, 2013 6:59 pm |
Angel projector lights.
Hey guys!
Okay, so basically it's my 18th Birthday today, and I'm due an MOT!
when't there blardy bla, Car is perfect. But there's one thing. My Angel lights!
I bought these from E-bay of EnergizedCustoms, for £125.00 in total (Black ones) And to put it blunt...They are dog POO. They blind drivers, shine to the right and not the left, they don't light up the road at all. I messaged the dealer, he said there's a pin or something. inside the lights? Should I go back to nomal lights? Or try figure these foreign pieces of crud out.
Posted: Fri Feb 01, 2013 7:52 pm |
Get your headlights set at your mechanics
Posted: Fri Feb 01, 2013 11:27 pm |
chrisd wrote: |
Get your headlights set at your mechanics |
Only works if they are E marked & also if the headlamps are for RHD.
If there LHD lights then chuck them in skip
Posted: Sat Feb 02, 2013 4:58 am |
MrBSI wrote: |
chrisd wrote: |
If there LHD lights then chuck them in skip |
Or....
You can flip a switch in the back that changes them from RHD to LHD. i had my angel lights for about 5 years and we're brilliant but over the years the plastic covers became scratched and cracked so when're back to crystals.
Posted: Sat Feb 02, 2013 5:20 am |
Where is this switch everyones talking about!?
Posted: Sat Feb 02, 2013 6:34 am |
They look s**t anyway so save the embarrassment and bin them.
Posted: Sat Feb 02, 2013 6:58 am |
Edward wrote: |
They look s**t anyway so save the embarrassment and bin them. |
It's personal opinion mate I think my sig looks rather good I prefure them over crystals any day as the side lights are in a rubbish possition and are hard to match with colour of bulbs.
It should be either a lever or on mine it was a bolt you turn
Posted: Sat Feb 02, 2013 7:41 am |
there's a white little bolt that adjusts allignment you can screw, I just need to find the pin to make the lights shine to the left and not the right =]
