Posted: Sat Feb 02, 2013 4:28 am |
Im after a good French car specialist in the midlands area to fit my clutch in my gti180. any recommendations guys?
Posted: Sat Feb 02, 2013 4:34 am |
and where is your area ???
Posted: Sat Feb 02, 2013 4:35 am |
| broadblaster wrote: |
| and where is your area ??? |
Staffordshire
Posted: Sat Feb 02, 2013 4:38 am |
lol i see you have alterd your first post bit out of my area mate so sorry no i don't but i'm sure somebody on here will be along soon with a person near you who can do it.
Posted: Sat Feb 02, 2013 4:42 am |
| lol i see you have alterd your first post bit out of my area mate so sorry no i don't but i'm sure somebody on here will be along soon with a person near you who can do it. | Yes ive just put my location on my profile just. Thanks for the help anyway.
Posted: Sat Feb 02, 2013 4:46 am |
no probs mate tbh its not that bad a job to do just make sure you fit a new input shaft seal/bearing at the same time, also worth changeing the driveshaft seals while your at it.
has your got the dreaded judder ???
Posted: Sat Feb 02, 2013 5:23 am |
You really don't need a French car specialist to fit a clutch on a 180. Any independent garage should be capable of doing what is a straight forward job.
Posted: Sat Feb 02, 2013 6:02 am |
Abp motorsport in crewe are alright
Posted: Sat Feb 02, 2013 8:31 am |
| Andy180 wrote: |
| Abp motorsport in crewe are alright |
Yes been there a few times when i had my saxo vts and 106 gti.There labour prices are a bit too high for me.
Posted: Sat Feb 02, 2013 8:42 am |
Birchdown is quite well regarded on clio sport and they were pretty reasonable when I had a quote for a cambelt change might be worth asking them for a quote, there near whitchurch
Posted: Sun Feb 03, 2013 2:54 am |
| Andy180 wrote: |
| Birchdown is quite well regarded on clio sport and they were pretty reasonable when I had a quote for a cambelt change might be worth asking them for a quote, there near whitchurch |
Yes they are good,they did work on my clio 182 few years back,but i thought they were clio specialists only?
Posted: Sun Feb 03, 2013 3:03 am |
They were willing to do the cambelt on my 180 so I recon they would do your clutch
Posted: Sun Feb 03, 2013 3:23 am |
| Andy180 wrote: |
| They were willing to do the cambelt on my 180 so I recon they would do your clutch |
Cheers andy i will give them a call.
