Posted: Sun Feb 03, 2013 9:25 am |
Could someone with a y2001 model 1.4i please take a pic of their throttle potentiometer and put it up?
Also, y2000 would be appreciated if possible.
Thank you very much.
Posted: Sun Feb 03, 2013 9:44 am |
As in the ones with later inlet manifold?
Ie
0-0-0-0 rather than the pre 2000 of 00-00?
| Team Impossible Possible
Posted: Sun Feb 03, 2013 12:04 pm |
Addaz wrote: |
Ie
0-0-0-0 rather than the pre 2000 of 00-00? |
Any pics of TPS wanted from 1.4i along with the year please.
Cheers.
Posted: Mon Feb 04, 2013 10:35 am |
V9977 wrote: |
Addaz wrote: |
Ie
Cheers. |
Waste of time as usual.
Bump for anyone else with 1.4i and a camera.
Posted: Mon Feb 04, 2013 10:38 am |
I can do you a 2003 TU3 throttle pot picture if that's any good to you matey?
Sagem S2000 management system.
Posted: Mon Feb 04, 2013 10:45 am |
MrBSI wrote: |
Sagem S2000 management system. |
Would be good as long as it's not motorised throttle obviously.
'Trying to confirm the right one is fitted after ECU/BSI replacement, as SB codes do not agree with what I have here I think.
Thanks.
Posted: Mon Feb 04, 2013 10:47 am |
V9977 wrote: |
MrBSI wrote: |
Mines old fashioned mechanical throttle cable set up, no crappy fly by wire throttle on my 206
Ill grab a picture tomorrow for you.
Posted: Mon Feb 04, 2013 10:54 am |
MrBSI wrote: |
V9977 wrote: |
MrBSI wrote: |
Ill grab a picture tomorrow for you. |
Great, thanks.
Posted: Mon Feb 04, 2013 12:38 pm |
V9977 wrote: |
V9977 wrote: |
Addaz wrote: |
Ie
Cheers. |
Bump for anyone else with 1.4i and a camera. |
I do have work and i was only clarifying on which type NOT offering.
So there is no need to be rude......
Posted: Mon Feb 04, 2013 3:18 pm |
Addaz wrote: |
V9977 wrote: |
V9977 wrote: |
Addaz wrote: |
Ie
Cheers. |
So there is no need to be rude...... |
OK
[Edited after proper thought]
Posted: Mon Feb 04, 2013 3:28 pm |
My apologies to for not replying, i usually forget on most things. Even when emailed
Im useless at the best of days since august
I will see if there is any 206's in the car park tommorow, or if any are in. If i had access to where my vehicle is stored (long story) i would be send you an image, but i dont. I think i have a 106 rallye throttle body molested for my 206 if that is any good?
Posted: Mon Feb 04, 2013 3:37 pm |
Addaz wrote: |
I will see if there is any 206's in the car park tommorow, or if any are in. If i had access to where my vehicle is stored (long story) i would be send you an image, but i dont. I think i have a 106 rallye throttle body molested for my 206 if that is any good? |
No worries mate.
I was out of line really and you are right about the rudeness.
Anyway, if Mr.BSI can get me a pic off his, that will solve it and no need to muck you about with the rallye!
Cheers again.
Posted: Mon Feb 04, 2013 3:41 pm |
V9977 wrote: |
Addaz wrote: |
No worries mate.
Cheers again. |
Its fine, now what did you want me to do again? (in other posts)
Side note you got facebook? As im on there more often must admit
Posted: Mon Feb 04, 2013 3:57 pm |
Addaz wrote: |
V9977 wrote: |
Addaz wrote: |
No worries mate.
Cheers again. |
Side note you got facebook? As im on there more often must admit |
I don't but I am a parasite on Mrs_V9977 page when I'm not moaning at her about it.
If you do get torque settings/procedure for the crank half-shell caps that would be brilliant! Not urgent at all though.
Posted: Mon Feb 04, 2013 4:59 pm |
V9977 wrote: |
Addaz wrote: |
V9977 wrote: |
Addaz wrote: |
No worries mate.
Cheers again. |
If you do get torque settings/procedure for the crank half-shell caps that would be brilliant! Not urgent at all though. |
Please message me tommorow and i will get the information over to you
