Forums › The Car › 206 Problems › temp gauge and fan wireing |
Posted: Sun Feb 10, 2013 11:39 am |
hi all got a 99 2.0 gti 206 got a few issues to sort before she comes back on the road
its got the usual fin wireing issuses so i buy passed the wireing and have it on a realy and switch but i want to put it back to standerd is a new loom cheap enough or is it worth repairing myne?
and on another note as soon as i start my car the temp gauge is at half way i have checked the temp with the aftermaket stack gauge out of my offroad buggy and it saying 88 degrees c when my temp gauge is in the red is the a comon issue?
thanks all for your help i understand that this has probly been asked before but i cant seem to find definative answers
| 206 gti run around\r\nhilux jacked up as a toy | |
Posted: Sun Feb 10, 2013 12:04 pm |
Just rewire the relays. It's just standard wiring bits and terminals.
Posted: Sun Feb 10, 2013 2:12 pm |
ideal thanks mate has anyone else had the temp gauge problem dont no wether to start with the sender or the gauge
