Online Now [92]:
Visitors: 91
Today: 14646
Total: 139089389
Forums › The Car › 206 Problems › Clunking Noise :S
Clunking Noise :S
Austin
PostPosted: Sat Feb 09, 2013 10:04 am Up
Hi guys,
My 2004 206 1.4 has got a clunking noise when turning on a car park or at slow speed. Can sit at standstill, turn the wheel and hear a clunking noise, sounds like a spring tensioning and releasing :S when driving and turning it doesn't do it. Any ideas??
Cheers
Austin Smile
TheGTIlad
PostPosted: Sat Feb 09, 2013 10:07 am Up
If you think it sounds like a spring tensioning then releasing, it could be a spring has broke and it gets caught then when you turn the lock further it releases again. Personally, I would have a close look at your suspension mate.
Fifer
PostPosted: Mon Feb 11, 2013 3:20 pm Up
Take a look at the bearing at the top of the spring.
www.206info.co.uk/Foru...52838.html
1.4hdi 02
spike_202
PostPosted: Mon Feb 11, 2013 4:07 pm Up
As aside above sounds like the top mount bearing is fooked and is struggling to move Freeley with the movement with the spring.
**spike's project**
TEAM:+200bhp
Austin
PostPosted: Tue Feb 12, 2013 4:46 pm Up
Cheers for the reply guys. Have had a quick look tonight, got the mrs to turn wheel whilst I was looking at the O/S/F strut. The strut and spring turn but then the spring seems to jump a couple of mm, this is when it clunks. Looking from the engine bay the black rubber on the top mount vibrates when it clunks aswell. I think your right, its the top mount bearing.
