Latest: DanDan17
Overall: 17128
Online Now [183]:
Visitors: 182
Today: 19357
Total: 100619770
Forums › The Car › 206 Talk › indicator problems
indicator problems
Simmo
PostPosted: Tue Feb 12, 2013 9:53 am Up
Hi guys, as some of you may know i have recently been in a crash and since then my indicators have not been working. My car makes a fast ticking noise when i indicate but no lights flash on the inside or outside of the car. I would have instantly thought it would mean a new fuse but i have know idea which one it is, has anyone got a digram of the fuse box which shows which ones are indicator fuses????? or is there something else wrong with the car???
1.1 silver style www.206info.co.uk/Foru...52484.html
PostPosted: Tue Feb 12, 2013 10:48 am Up
Search on here in the FAQ: Identify Your Car section for fuse list. There are 2 separate threads, one for multi-plex and one for pre-plex
DeadEyePaul
PostPosted: Tue Feb 12, 2013 10:52 am Up
The fast click is your car telling you there is a fault. When I had this problem I discovered one of the wires going to the bulb had perished so I cut the wire back and added a new length of wire with soldering iron
Simmo
PostPosted: Tue Feb 12, 2013 12:07 pm Up
If one indicator is unplugged does this affect all the rest?
DeadEyePaul
PostPosted: Tue Feb 12, 2013 12:19 pm Up
No just the side you unplugged
PostPosted: Tue Feb 12, 2013 5:15 pm Up
Not all, but it does make that side flash quickly to tell you there is a blown bulb.
Simmo
PostPosted: Tue Feb 12, 2013 5:32 pm Up
Ah right, well none work at all, don't even flash to let me know my car is locked so it take it fuse? Also what is the difference between pre plex and multi plex?
spike_202
PostPosted: Tue Feb 12, 2013 5:39 pm Up
That's is all explained in the FAQ noob bit
**spike's project**
TEAM:+200bhp
Simmo
PostPosted: Tue Feb 12, 2013 5:54 pm Up
Haha noob bit, just checked both lists and still can't see where it's days which fuse covers indicators
Simmo
PostPosted: Tue Feb 12, 2013 6:13 pm Up
it says to tell if you have multiplex or not look at your radio stalk. I take it the radio stalk with buttons on it is multiplex and the one without buttons on it is preplexed??
spike_202
PostPosted: Tue Feb 12, 2013 7:01 pm Up
From looking at your project thread your car looks to me to be pre-plexed
**spike's project**
TEAM:+200bhp
Simmo
PostPosted: Wed Feb 13, 2013 6:27 am Up
but there is still no indicator fuse listed
