Online Now [376]:
Visitors: 374
Members: 1
Today: 66452
Total: 156173668
Go to page Previous  1, 2, 3 ... 8, 9, 10, 11  Next
Schumi
PostPosted: Tue Oct 16, 2012 3:38 am Up
Same pistons as mine. Very Happy Can you measure weight of thet conrods with screws please?
2005 206 RC RED
briant
PostPosted: Mon Dec 31, 2012 12:54 pm Up
Another little update i have finished my gearbox build which i fitted the ratios from a 180 gearbox with low 1st gear to my 137 rod change box also fitting 4.5 CWP and a Quaife ATB diff
Apoligies for poor pic quality as i only had my phone with me
4.5 CWP
Quaife ATB
I would ideally like a close ratio gear kit but the lower 1st & 4.5CWP will suffice for the moment
For those who are curious using 17" wheels & 7000rpm shift point
137 1st gear is 3.455:1 rev drop 1st to 2nd 3211RPM
180 cable change box 1st is 2.923:1 rev drop 1st to 2nd 2522RPM
Quaife kit 1st is 2.692:1 rev drop 1st to 2nd 1974RPM
Standard CWP in 137 = 3.79:1
If any one wants complete rev drop & top speed for each gear i can post it up for both boxes
All the rest of the Gear ratios 2nd-5th are same in both 137 & 180 boxes
I swapped into 137 box as i wanted to keep rod change instead of cable change
I also finished seam welding my subframe and strengthened the gearlever mount & painted it up
I fitted my PEC Steel Rods,Wossner pistons,Billett Flywheel,Helix Paddle clutch & Alloy Crank Pulley, New main & big end bearings
Dial Guage to locate Actual TDC for dialing in Cams later
Actual TDC
Lastly for now a pic of the spacer unit yo extend Steering rack/track rod arm
Steering rack with extended rack adapters & longer boots fitted ready to refit to subframe
206 Rallycar
briant
PostPosted: Mon Dec 31, 2012 1:01 pm Up
Apoligies Schumi i didnt see your request for weight i did check the weight pistons & rods to match but didnt really make any note of indivudal parts
Sorry
206 Rallycar
macj
PostPosted: Mon Dec 31, 2012 1:52 pm Up
Looking good bud......... cant wait to see it on the rollers now
PostPosted: Mon Dec 31, 2012 2:32 pm Up
That subframe is almost as clean as mine!
briant
PostPosted: Mon Dec 31, 2012 2:41 pm Up
id say underneath of your car is much cleaner Sad that is the only time it will ever be that clean Very Happy
206 Rallycar
macj
PostPosted: Mon Dec 31, 2012 4:13 pm Up
just a little incentive.... just got the results for our 2012 championship.... we finished 3rd in our class.... not too shabby Very Happy
Schumi
PostPosted: Tue Jan 01, 2013 5:07 am Up
Sorry
No problem. I bought Wössner pistons but still didnt bought any conrods. Wiseco K1 Tech conrods 40 gr heavier than stock gti180 conrods. Wössner conrods 30 gr lighter then stock gti180 one but price is almost double. I'm still thinking.
2005 206 RC RED
briant
PostPosted: Tue Feb 12, 2013 7:40 pm Up
I Eventually have my engine rebuilt with
PEC Steel Con Rods
Wossner High Compression Pistons
2mm Oversize Inlet & Exhaust Valves
Piper Cams
Piper Uprated Valve Springs
Piper Hydraulic Followers
Piper Vernier Pulleys
Billet Flywheel
Complete Balanced bottom End
New Main & Big End Bearings
New Timing Belt kit & Water Pump
Helix Paddle Clutch Kit
so its ready to bolt up to gearbox & refit all going to plan it will be back in at weekend Very Happy
206 Rallycar
spike_202
PostPosted: Wed Feb 13, 2013 1:18 am Up
Good idea on strengthening gear linkage pivot as that's what I had to have done 'after' I snapped mine. Good choice on the fly wheel also I couldn't be leave the difference between the weights.
**spike's project**
TEAM:+200bhp
Aar_Im_A_Pirate
PostPosted: Wed Feb 13, 2013 5:12 pm Up
Keep er lit!
Team: Derv
briant
PostPosted: Tue Feb 19, 2013 6:16 pm Up
Maniflow Manifold arrived today
Fitted to engine
206 Rallycar
briant
PostPosted: Fri Mar 01, 2013 4:29 pm Up
Got the engine back in & modified the airbox to suit throttle bodies,
need to sort out cold air feed to the airbox then its all ready for final fit
Here is a few pics of progress
206 Rallycar
Schumi
PostPosted: Sun Mar 03, 2013 5:42 am Up
How bonnet will close with that Airbox. Your inlet manifold simply straight. Not curved like Jenvey one. Good luck with your bonnet clearance.
2005 206 RC RED
PostPosted: Sun Mar 03, 2013 6:37 am Up
As for gear ratios, I think this website is useful...
www.teammfactory.com/g...rannytype=
Page 9 of 11
