Online Now [241]:
Visitors: 241
Today: 100021
Total: 155703095
Forums › The Car › 206 Problems › Gti 180 water pump housing
Jammie_1989
PostPosted: Thu Feb 14, 2013 7:34 am Up
I had a cambelt fitted about 10 months ago and the garage didn't do the water pump as they said they tested it and it didn't need doing. As always the ba**hard went about a month ago and they fitted a new one at a reduced rate for me.
Now the car has a water leak on the housing which the water pump fits too. This can only be ordered from peugeot and I'm guessing it is expensive. They have said it will cost another £340 to sort this out. Its a bit suspicious that what has gone is connected does this seem strange to anybody else?
Also that price includes a new CV joint and fitting and VAT
206 gti 180
206gti_chris
PostPosted: Thu Feb 14, 2013 9:08 am Up
what a s**t garage. im guessing the housing is part of the water pump? im not sure maybe buy a whole new water pump which is about 48 quid which has the housing on ECP get it fitted by another garage should only cost you 1 hour labour, and u saved urself 240 quid
PostPosted: Thu Feb 14, 2013 11:33 am Up
Is it the housing or the pipe that goes into the housing? It might just be the seal between the two.
Jake86
PostPosted: Thu Feb 14, 2013 12:04 pm Up
When my cambelt and water pump were changed last year the housing was cracked. The garage showed me it when I picked it up and with them removing the water pump a chunk had broken off but there were other cracks too. They reckoned it was probably due to it being sat under the exhaust manifold and the constant heat cycles it was put through. They didn't break down the costs of parts on the bill but it didn't add much to the total.
karimali831
PostPosted: Thu Feb 14, 2013 5:43 pm Up
I keep thinking about my water pump, I hit 100k now and had cambelt changed 84k and they didn't change the pump!! Evil or Very Mad They said it needs to be changed every second cambelt change, can I expect it to last that long. Shocked
206 GTI 180
PostPosted: Fri Feb 15, 2013 1:55 am Up
Keeping a good coolant mix will help.
Jammie_1989
PostPosted: Sun Feb 17, 2013 10:19 am Up
Its the housing. They said that the CV boot has a split in it and the housing is directly above the CV boot and they think whatever has caused that has f**ked the housing as well. I feel ripped off as I've already spent more than enough on them fixing the pump itself. Going to get another garage to look at it and give me a second opinion and a quote.
206 gti 180
