Latest: sparrowdclxvi
Overall: 17139
Online Now [61]:
Visitors: 60
Today: 11108
Total: 112523852
Forums › The Car › 206 Problems › Blue Angel light projectors
T0BEZ
PostPosted: Thu Feb 14, 2013 5:59 pm Up
Hey guys Toby here with another problem Wink
So these are my lights;
(I know the blue is Illegal, so I've put my original xenon bulbs back in)
I wanted, to know, how to get the other 2 halos blue, Is there a seperate bulb inside the casing of the angel lights?
I thought it was the sidelight bulb that made them all go, so I bought a blue sidelight bulb x) [Wasn't that as I've found out Razz ]
Any advice will be helpful Smile
RoweY
PostPosted: Fri Feb 15, 2013 5:09 am Up
Need to buy a blue headlight bulb mate Very Happy
PostPosted: Fri Feb 15, 2013 5:18 am Up
I thought they were LED's in the ring. From the picture it looks like 5 hotspots in each one.
You may have to dismantle the headlamps to get to them to check what you need.
shadow
PostPosted: Fri Feb 15, 2013 7:29 am Up
there is basically2 types of LED ones, circuit board type which is fitted by means of tiny screws for each light that fit in line with the ring easy to change but alot of work to get to, the other type is moulded in so no chance of changing as they are as one unit again a lot of work to get to. i,ve not done any on a 206 but have done plenty of other similar headlights.
206cc 2.0 allure
