Latest: heikkisj
Overall: 17126
Online Now [56]:
Visitors: 55
Today: 19263
Total: 100328602
Forums › The Car › 206 Problems › heeeellllllllpppppp!!!!!!!!
parker81
PostPosted: Fri Feb 15, 2013 4:28 am Up
a couple of months ago i bought a y reg pug 206 which at the time seemed like a lovely car....great to drive ran as smooth as a babys a**e. knew it was due for mot, car looked fine when checked it over and ran mint. after taking it for new tyres i discovered that the wish bones needed replacing on either side ready for the mot. before i fitted these i decided that i should take it for an mot knowing that it would fail to make sure that there was nothing else seriously wrong with it. however my wife took ill so i took her to the hospital a and e then parked the car in the supermarket car park next door. when i fetched the car it kept cutting out with no warning at all but would start again fine with no problems. no lights came on the dash and the car was driving fine it lost all power 7 maybe 8 times then was fine. i took the car for the mot and as suspected it failed on lights wishbones and emissions. so i took the car home home and replaced all the bulbs took hid conversion kit off the front and put standard bulbs back in replaced the drivers seat belt started the car to check the lights and it was fine. by this time it was dark so left the rest till morning. however the next day when i attempted to start the car there was nothing it cranks but wont fire. so i called a mechanic he checked all the wires theyre fine, we changed the coil pack as there is no spark and the new 1 didnt get a spark either so we tried the plugs that didnt work. i tried to bump it and nothing also tried to drag it but nothing the exhaust just puffs smoke as if its trying to start. ive even had the rac and they cant find the fault. when it was plugged into a computer a list of faults came up but were able to clear them. turned on the ignition and they were back again. i have no idea what the problem is does anyone have any ideas on what to try now??????
PostPosted: Fri Feb 15, 2013 4:31 am Up
2 tips:
1) Putting " heeeellllllllpppppp!!!!!!!! " as your thread title just makes most long term forum members not even bother reading your thread.
2) Try using paragraphs & punctuation to break up the text as I just gave up after the first line, BIG block of text = just cant be bothered to read it.
PostPosted: Fri Feb 15, 2013 4:33 am Up
Is the car cranking over at all?
Have you got another key you could try?
Could really do with the list of faults it's chucking up to diagnose what the problem is.
johniban
PostPosted: Fri Feb 15, 2013 5:32 am Up
For a start i wouldnt bump start it or tow strt it as it hasnt got a wood ruff key, this could cause a world of sh't if the bottem pulley slipped..
the random cutting out i would have a look at the igntion barrel it bad need a new one or possibly the earth strap broken?
you havnt said what engine it is, i guessed it was gti
parker81
PostPosted: Fri Feb 15, 2013 6:02 am Up
not got the fault codes with me at the min will try and get the list later when i get home. the engine is 1.1 checked all the ignition barrel and earthe wires tested all of the wires into the ecu alternator everything i can think of tried both keys it cranks but just wont fire even topped up the petrol and checked that the injectors work and all that is fine. even tried flooring accelorator while turning key but again just cranks and gives a slight misfire when turning off ignition
parker81
PostPosted: Fri Feb 15, 2013 6:04 am Up
is there any chance that it could be a fault with the ecu thats not sending the right signal to the coils?
spike_202
PostPosted: Fri Feb 15, 2013 6:12 am Up
Have you checked the spark plugs?
**spike's project**
TEAM:+200bhp
What year?
parker81
PostPosted: Fri Feb 15, 2013 6:13 am Up
checked all spark plugs and replaced them still nothing and its a 2001 y reg
parker81
PostPosted: Fri Feb 15, 2013 6:18 am Up
sat on forums and websites for hours reading about what it could be tried everything that has been suggested yet cant get to the bottom of the problem, starting to theink that a litre of petrol and a match is a good solution or just drop a gti engine in
PostPosted: Fri Feb 15, 2013 6:29 am Up
Thumbs Up
parker81
PostPosted: Fri Feb 15, 2013 6:34 am Up
fine 1 day and fooked the next lol been like that for a week now, maybe a new battery will work
efeash
PostPosted: Fri Feb 15, 2013 9:18 am Up
has it got petrol in it ????
ash
Fifer
PostPosted: Fri Feb 15, 2013 9:27 am Up
Crank position sensor. Sptoms are - car will randomly cut out. Car will also run fine sometimes and fail to start at others. When the car wont start check the leads for no spark and check to see if the fuel pump is working. If the crank position sensor is failing you wont get any of these as the ecu doesnt know where the crank is so cannot operate.
1.4hdi 02
Fifer
PostPosted: Fri Feb 15, 2013 9:29 am Up
Double post
1.4hdi 02
