Posted: Thu Feb 14, 2013 5:59 pm |
Posted: Fri Feb 15, 2013 5:09 am |
Need to buy a blue headlight bulb mate
Posted: Fri Feb 15, 2013 5:18 am |
I thought they were LED's in the ring. From the picture it looks like 5 hotspots in each one.
You may have to dismantle the headlamps to get to them to check what you need.
Posted: Fri Feb 15, 2013 7:29 am |
there is basically2 types of LED ones, circuit board type which is fitted by means of tiny screws for each light that fit in line with the ring easy to change but alot of work to get to, the other type is moulded in so no chance of changing as they are as one unit again a lot of work to get to. i,ve not done any on a 206 but have done plenty of other similar headlights.
