Latest: flipflap
Overall: 17140
Online Now [568]:
Visitors: 567
Today: 79603
Total: 113879489
Forums › The Car › 206 Problems › Changed 2 bulbs now the car won't fire.
Go to page Previous  1, 2
mosimo
PostPosted: Sun Dec 12, 2010 5:10 am Up
Pro Tip: playing in the fusebox in the dark with a dodgy torch = bad.
I'm not sure how it happened but the Fuse for the BSI, a 5A one in slot 5 had got moved to the spare slot 4. Not sure how I managed to do that as the light fuses are 2 rows down and are 10A ones. But for some reason I must have taken that one out to test it. I know I took it out after the thing wouldn't start, but before that is beyond me.
Anyway, the thing fires now and everything works. I'm glad nobody answered the phone at the garage yesterday meaning I was waiting for Monday to ring back Razz
Cheers for your help on this one guys. o/
[DTE]
Rob2859
PostPosted: Sun Dec 12, 2010 6:10 pm Up
same problem as me then. even though it was the the same fuse it was for some minor electrical, boot bulb i think. replaced it and it started
DAVEY3478
PostPosted: Mon Dec 13, 2010 5:48 am Up
Have you definately not flooded the engine mate, you havent started engine on a cold morning then changed your mind and turned it straight off because that can flood the engine.
206 GTI
PostPosted: Mon Dec 13, 2010 10:29 am Up
Shouldnt do on a 206, its not got Japanese mapping for coldstart warmup cycle in the ecu Laughing
parker81
PostPosted: Fri Feb 15, 2013 4:58 pm Up
i have the exact same probably with my car its a 2001 1.1 replaced the convertion kit with standard bulbs ready for the mot, been rackin my brain for almost a week now. scanning the net all over the forums checking the wiring loom replacing sensors, changing coils pack checking fuses even had the rac scrathing their brain boxes over it next step is the immobiliser as a last resort. been told that a local garage will only 40 quid to take the bloody thing off
Tiago
PostPosted: Sat Feb 16, 2013 10:52 am Up
I had a starting problem when I shorted the boot light by accident, it blows the one of the fuses which is linked to the fuel pump. Stupid really but always worth checking.
PostPosted: Sat Feb 16, 2013 3:32 pm Up
Rob2859 wrote:
At the end of the coil pack there is a little cap. if you take that off and try to start it a bit of petrol should squirt out. this will confirm the car has fuel and its the immobilisr stopping the car from starting.
I think you mean the fuel rail and it's in the middle. Pressing the schraeder valve will just confirm there is fuel in the rail. It won't show if it's under pressure and it won't prove if the injectors are firing or not.
Rob2859
PostPosted: Sat Feb 16, 2013 7:19 pm Up
I did mean the rail. I realise now that I was a bit out. That was some time ago Very Happy
Page 2 of 2
