Latest: Andyblue64
Overall: 17123
Online Now [452]:
Visitors: 451
Today: 40467
Total: 98551839
Forums › The Car › 206 Problems › A few problems
A few problems
dan1995206
PostPosted: Sat Feb 16, 2013 3:02 pm Up
My rear right tail light had a lot of water in it so i removed the light and drained the water out. i then dried the lamp holder (lightly) with a hair dryer and when i plugged it back in it didn't work. I've had a fiddle with it and now the indicator is working and the side light but the not the brake light? can't find a blown fuse and the bulb works as i swapped it with the left side. anyone have any ideas they're just standard ph1's.
PostPosted: Sun Feb 17, 2013 4:14 am Up
I had this..
Bin them.
Fifer
PostPosted: Sun Feb 17, 2013 5:39 am Up
Clean the connections that the bulb sits in
1.4hdi 02
PostPosted: Mon Feb 18, 2013 6:41 am Up
Once the plating goes on the contacts they'll keep corroding and putting bulbs out without you knowing.
This is an issue when you replace bulbs and disturb the seized contact surfaces, so even if you clean them and put new bulbs all round some stop working after a while.
The holders in the phase 1 rear lights are terrible for this.
Domo
PostPosted: Mon Feb 18, 2013 7:05 am Up
just buy a new set phase 1's they cheap to buy. ill sell u a set in imacculate condition with back plates if you want, pm me
