Online Now [389]:
Visitors: 388
Today: 168088
Total: 155460963
Forums › The Car › 206 Problems › morette odd wires?
morette odd wires?
paulspug
PostPosted: Tue Feb 19, 2013 10:48 am Up
hi.
i have looked through the forums and have sort of found the answer i require but am little bit unsure.
these morettes have already been wired up - from another that was scrapped - but i am still unsure wether my car requires the same wiring.
in both pictures there is a yellow wire that from what i read has to be grounded.The bigger arrow shows a longer wire that i belive shoud go to the battery ( with in line fuse ofc ).
my car is a multiplexed (2002), so is it still right or do i not require the relay that has already been wired up?
Also if i still need to wire to battery , what amp fuse should i use?
many thanks
iainlovatt
PostPosted: Tue Feb 19, 2013 10:50 am Up
Top one is an earth! So attach it to chassis of car!
Bottom one need end cutting off it and connecting to power. Ie battery!(long wire) There is also a cable that need earthing on the bottom one too!
(My Garage)
iainlovatt
PostPosted: Tue Feb 19, 2013 10:54 am Up
wouldnt bother putting fuse in! More hassle than its worth imo! They are fused anyway on car circuit.
You still need to wire them up even though your car is 2002. Earth each light, and attach the passenger one with the long wire to the battery, then plug and pay with rest of wires and you are away!!
(My Garage)
paulspug
PostPosted: Tue Feb 19, 2013 10:55 am Up
thanks bud Very Happy
any idea what fuse i should inline to the battery?
ty
paulspug
PostPosted: Tue Feb 19, 2013 10:56 am Up
ahh ok - replied too soon lol
no fuse ,ty
PostPosted: Tue Feb 19, 2013 1:31 pm Up
fyi, should look something like this when done:
img401.imageshack.us/i...891759.jpg
img35.imageshack.us/im...p5251i.jpg
paulspug
PostPosted: Tue Feb 19, 2013 5:02 pm Up
Thats great
thanks DJ-
