Posted: Mon Feb 18, 2013 3:13 pm |
Ok so my gti 137 has been getting this light very regularly lately and at first it didn't affect performance, now it feels like its misfiring and underpowered when it comes on and I have to plant my foot to get moving, plus it sounds like a tractor when its on!
any advice on what to do and whether or not there is a solution as ive read lots of different things!
cheers!
Posted: Mon Feb 18, 2013 3:51 pm |
You will read a million answers, only proper solution is to get it code read. What year is it?
Posted: Tue Feb 19, 2013 4:35 am |
cat or sensor
Posted: Tue Feb 19, 2013 8:55 am |
03, with it being intermittent will it still come up on the code reader?
Posted: Tue Feb 19, 2013 10:56 am |
if it sounds like a tracktor it might be your coil pack??? very easy to sort out yourself.
Posted: Tue Feb 19, 2013 12:34 pm |
| bigp2013 wrote: |
| 03, with it being intermittent will it still come up on the code reader? |
Yes the code is probably still stored. As said best way is to plug it in really and go from there, could end up wasting a whole load of time & money replacing things that are okay otherwise.
Posted: Tue Feb 19, 2013 1:30 pm |
| 138Andy wrote: |
| cat or sensor |
See what i mean! Get it code read for the most accurate answer, does sound like coil pack or spark plugs though.
Posted: Tue Feb 19, 2013 1:33 pm |
Even a hole in the exhaust after the cat can trigger ANTIPOLLUTION FAULT.
Without reading the fault codes your just p**sing in to the wind.
Posted: Tue Feb 19, 2013 1:56 pm |
Had this pop up this morning on the GTi. runs fine (except the lumpy idle for few minutes when completely cold) no loss of power. hoped it would sod off,reset the BSI and it came straight back. Was used last month for a 600mile roundtrip so that would have cleaned out any crud,isnt blowing. will check lambda #2 though as just re-hung the centre exhaust-work as rubber was worn and loose,might have knocked sumat. if not,fault readin time...........just thought i'd join the fun/pain of peugeot life lol
| Joined the GTi massive 10/1/13
Goodbye lairy Pugani (quicksilver 1.4)  | |
Posted: Wed Feb 20, 2013 12:36 pm |
update....BSI reset didnt work,was on all day,gave up,drove 2 miles to mates and it disappeared lol....gotta luv pugs
Posted: Wed Feb 20, 2013 4:48 pm |
would have put my money on the coil pack mate
