Online Now [50]:
Visitors: 49
Today: 35036
Total: 116577414
Forums › The Car › 206 Problems › gti 180 ticking noise from rear
gogs_macaulay
PostPosted: Sun Feb 24, 2013 5:24 pm Up
when i turn a sharp left or right i get a loud "tick" noise coming from the rear. i have jacket the car up to check for play in both rear wheels and there is none. what could it be?
DanT
PostPosted: Sun Feb 24, 2013 7:00 pm Up
Arb end plate?
jase123
PostPosted: Mon Feb 25, 2013 5:45 am Up
Noise can travile. And often throw you out check the front track rod ends
Signature removed due to size
gogs_macaulay
PostPosted: Wed Feb 27, 2013 4:37 pm Up
nope diffo from the rear, Dan this could be it? how do i check this? and can the end plates them-self be changed?
gogs_macaulay
PostPosted: Sat Mar 02, 2013 5:22 am Up
bump..........
DanT
PostPosted: Sat Mar 02, 2013 5:45 am Up
www.slikweb.co.uk/arro...dplate.jpg
That bolt shown mate. Sometimes it can work loose and cause a noise like you mentioned. Check its tight but sometimes they have been known to snap so be careful.
gogs_macaulay
PostPosted: Mon Mar 04, 2013 4:13 am Up
Top lad, this was the problem, tightened up the bolt and the noise is gone.
