Posted: Wed Feb 27, 2013 3:29 pm |
Trade Rating: +13
Is it possible to swap the interior light in my 2005 sport for one with a map reading light like the gti's have?
Would it be plug and play or would I need to re wire it? If so what is the best way and what should I look out for (common mistakes)?
Posted: Wed Feb 27, 2013 3:46 pm |
Yes, you need the roof trim panel.
The connector plug for the map light MAY already be there but without having a look its 50/50 chance
If the connector isn't there then you will need to wire it up your self.
Posted: Wed Feb 27, 2013 3:57 pm |
Trade Rating: +13
Ok thanks I will take a look. If I do not have the connector how do I wire it up? Not really experienced with car electrics. Do I need special wires? Do I come off existing wires and tape or use joining blocks?
Posted: Wed Feb 27, 2013 4:00 pm |
I spliced in to the interior lamp wiring.
I borrowed the connector plug out the 206 I got the map light from.
Posted: Wed Feb 27, 2013 4:20 pm |
Trade Rating: +16
There are three wires behind the interior light a permanant live, earth and switched live, make sure you scotch block it to the permanant live and earth.
A continuety meter will tell you which is which.
Posted: Wed Feb 27, 2013 11:13 pm |
Trade Rating: +13
Thank you both
Posted: Thu Feb 28, 2013 10:43 am |
QuArTz wrote: |
scotch block |
Nasty bodge
Posted: Thu Feb 28, 2013 11:21 am |
Trade Rating: +13
MrBSI wrote: |
QuArTz wrote: |
scotch block |
Nasty bodge |
How would you do it? What would you use?
Posted: Thu Feb 28, 2013 12:32 pm |
Solder & heat shrink.
Posted: Thu Feb 28, 2013 12:34 pm |
Trade Rating: +13
Ok will do thanks
