Latest: Andyblue64
Overall: 17123
Online Now [42]:
Visitors: 41
Today: 22638
Total: 98003782
Forums › The Car › 206 Talk › Interior light swap
Interior light swap
Tolkienfan001
PostPosted: Wed Feb 27, 2013 4:29 pm Up
Trade Rating: +13
Is it possible to swap the interior light in my 2005 sport for one with a map reading light like the gti's have?
Would it be plug and play or would I need to re wire it? If so what is the best way and what should I look out for (common mistakes)?
2005 1.4 16v Sport
Check out my 206 here!
PostPosted: Wed Feb 27, 2013 4:46 pm Up
Yes, you need the roof trim panel.
The connector plug for the map light MAY already be there but without having a look its 50/50 chance Laughing
If the connector isn't there then you will need to wire it up your self.
Tolkienfan001
PostPosted: Wed Feb 27, 2013 4:57 pm Up
Trade Rating: +13
Ok thanks I will take a look. If I do not have the connector how do I wire it up? Not really experienced with car electrics. Do I need special wires? Do I come off existing wires and tape or use joining blocks?
2005 1.4 16v Sport
PostPosted: Wed Feb 27, 2013 5:00 pm Up
I spliced in to the interior lamp wiring.
I borrowed the connector plug out the 206 I got the map light from.
QuArTz
PostPosted: Wed Feb 27, 2013 5:20 pm Up
Trade Rating: +16
There are three wires behind the interior light a permanant live, earth and switched live, make sure you scotch block it to the permanant live and earth.
A continuety meter will tell you which is which.
Tolkienfan001
PostPosted: Thu Feb 28, 2013 12:13 am Up
Trade Rating: +13
Thank you both
2005 1.4 16v Sport
PostPosted: Thu Feb 28, 2013 11:43 am Up
QuArTz wrote:
scotch block
Nasty bodge Wink
Tolkienfan001
PostPosted: Thu Feb 28, 2013 12:21 pm Up
Trade Rating: +13
MrBSI wrote:
QuArTz wrote:
scotch block
Nasty bodge Wink
How would you do it? What would you use?
2005 1.4 16v Sport
PostPosted: Thu Feb 28, 2013 1:32 pm Up
Solder & heat shrink.
Tolkienfan001
PostPosted: Thu Feb 28, 2013 1:34 pm Up
Trade Rating: +13
Ok will do thanks
2005 1.4 16v Sport
