Latest: ArtistKS
Overall: 17145
Online Now [88]:
Visitors: 87
Today: 11773
Total: 115911794
Forums › The Car › 206 Problems › Juddering...running out of ideas :(
Mr-Tigger
PostPosted: Sat Mar 02, 2013 12:11 pm Up
sorry for the overload of information here but figure the more the better. so the GTI has a lumpy idle when cold but smoothed out once warm and dropped to 800rp, and held steady no problems.
Took it to surrey to see old man Krisb to get the cambel tensioner and water pump done,since then it is continuing to run lumpy when hot. idles fluctuates a minor amount (maybe 150rpm) down,and the juddering isnt constant but its there at least every few seconds but a lot gentler.
Ive cleaned out the plug-wells and plugs (stupid NGK but they were in before anyway) two are slightly white/grey and not smooth. Also went to clean out the throttle body but it was pristine almost. Have finally taken it for a good raggin with some redex (i know,before the ney-sayers start lol) but its still lumpyish.
It has thrown up the cat/anti-pollution fault twice,both times clearing itself after 20miles general driving,once before and once since cambelt was done.
Any suggestions before i end up forking out silly money for machine-time to test it?
forgot to add,does sound like its blowing a tad at the exhaust and does give a bit of a wobble when ya stop the engine but not all the time
Thanks guys
Mr-Tigger
PostPosted: Sat Mar 02, 2013 1:10 pm Up
ok,hopefully i answered my own question there,forgot how much pugs dont like fekn NGK,gna grab some super4's tomorrow from rip-off halfrauds (£22) and hopefully that will sort it
PostPosted: Sat Mar 02, 2013 1:33 pm Up
well you got that right,the NGK and Peugeot cars hate each other Smile
Mr-Tigger
PostPosted: Sat Mar 02, 2013 2:47 pm Up
hopefully enough to cause this judder/misfire,but not enough to have buggered me coilpack as i forgot to check whether it was the sagem or bosch.....though tbh didnt see an obvious brand anywhere on it
PostPosted: Sat Mar 02, 2013 3:09 pm Up
Did krisb do the cambelt change? His work is usually impeccable. Don't know if the timing would have anything to do with it.
Mr-Tigger
PostPosted: Sat Mar 02, 2013 3:46 pm Up
yup,he did it,lucky lad found out hard way it was floating pulley too lol. another mate said was timing right but it did it before cambelt was done when cold,only now keeps doin it when warm. gna get ripped off at halfords tomorrow and see if that does the trick
PostPosted: Sun Mar 03, 2013 1:07 pm Up
What are the stored ecu codes?
Mr-Tigger
PostPosted: Sun Mar 03, 2013 1:26 pm Up
waiting to get that sorted tonight hopefully,but had a look at few the main culprits. cleaned throttle body,new plugs,cleaned ICV buuuut didnt realise how it worked so put it back in without testing if it actually moves lol. DID find a small hole in exhaust in the join between backbox and centre pipe. and spraying carb cleaner didnt reveal any obvious leaks on intake seal,though didnt have the a**e to check for cracks other than areas visible from above. been a fun day for a n00b lol
