Posted: Sun Mar 03, 2013 8:28 am |
I recently asked @MrBSI in the shout block about the Crystal headlights. My car is a 2001 (51 reg) Pre plexed therefore still has the three pin plugs on it whereas the new crystal headlights look as though they are a different plug. I have already worked out i need an adaptor and he also mentioned a new stalk. Are the stalks with front fog lights on them most likely to work with the double optic lights? If not can someone help me find what I'm looking for, I need a stalk with front fogs and double optic option on it.
Posted: Sun Mar 03, 2013 8:39 am |
You mean one of these?
www.eurocarparts.com/e...c76&000312
Check behind the headlamps in case your car was one of the ones built with the loom for both types of headlamps. The plugs may be tucked away somewhere.
Posted: Sun Mar 03, 2013 11:51 am |
Yeah I guess that's it, will it work with the double optic lights aswell? And I'll check if there is a hidden socket. Cheers
Posted: Sun Mar 03, 2013 3:39 pm |
Does anyone know what the light adapter is specifically called? i cant find it on the internet.....
Posted: Mon Mar 04, 2013 3:42 am |
H4 - H7 adaptor. I'm pretty sure they are available from the dealer. Failing that, just get 4 H7 plugs and solder and heatshrink them to the existing loom/
Posted: Mon Mar 04, 2013 9:56 am |
Posted: Mon Mar 04, 2013 10:56 am |
| macca1411 wrote: |
| H4 - H7 adaptor. I'm pretty sure they are available from the dealer. Failing that, just get 4 H7 plugs and solder and heatshrink them to the existing loom/ |
I've got a pair of grey H7 plugs to solder on to a non plexed frosted headlamp 206 this week, mate of mine is doing a crystal headlight conversion
