Online Now [658]:
Visitors: 657
Today: 103202
Total: 156981127
Forums › The Car › 206 Talk › h4 bulbs on a 180?
h4 bulbs on a 180?
Forum Index › 206 Talk
gtijames22
PostPosted: Wed Mar 06, 2013 4:25 pm Up
allright lads i currently got my 180 with a xenon conversion and was wondering if the standard bulbs (non xenon) are the h4 ones. if i get pulled by the police then atleast i can quickly change them, is it a 3pin connector because i seen that while changing the sidebulbs,
thanks and p.s its an 05 plate
GTI 180 JIM
L5_UKS
PostPosted: Wed Mar 06, 2013 4:27 pm Up
h7
gtijames22
PostPosted: Wed Mar 06, 2013 4:29 pm Up
well why is there a 3 pin connector?
GTI 180 JIM
PostPosted: Wed Mar 06, 2013 5:23 pm Up
What headlights has it got? Standard crystals should have h7 bulbs. Also, just because you can change a bulb roadside, isn't going to stop you getting points or fined.
mtempsch
PostPosted: Thu Mar 07, 2013 12:34 am Up
The bulb type should the readable molded into the plastic at the top of the housing.
The plug that connects to the housing is 3 pin because it carries +12V for dipped beam, +12V for full beam, and common ground.
Inside the housing it splits into 2x 2-pin plugs with +12V and ground for respective bulb.
2x
There is no 'H4-style' 3-pin connector (at least in my wiring loom) that can plug onto an H4 bulb.
Functionally it also differs in that for a H4 bulb only one of the 12V feeds is active at a time (i.e. either full or dipped is on, never both) while on the dual H7 bulb setup, dipped beam remains on together with the full beam.
Silvermetallic 2004 206 RC
gtijames22
PostPosted: Thu Mar 07, 2013 12:55 pm Up
cheers lads, well i only gave it a quick glance, i didnt think it was a h4, yeah they are standard crystals.
GTI 180 JIM
Ash
PostPosted: Thu Mar 07, 2013 1:27 pm Up
"Sorry officer, I'm just going to get my illegal lights out and get the normal ones I purposely left in the boot for when you pull me. Obviously, you don't have to fine me now. And I promise I won't change them back after. Honestly"
Deserve to be caught and fined Smile
gtijames22
PostPosted: Thu Mar 07, 2013 1:41 pm Up
lol i meant change them at home an sell the kit, whats up with u, someone stole your pokemon cards?
GTI 180 JIM
Ash
PostPosted: Thu Mar 07, 2013 1:46 pm Up
Ohh then my apologies Wink
gtijames22
PostPosted: Thu Mar 07, 2013 1:48 pm Up
no probz lol
GTI 180 JIM
