Latest: TigerHunters
Overall: 17144
Online Now [63]:
Visitors: 62
Today: 6105
Total: 115879476
Forums › The Car › 206 Problems › No Acceleration
No Acceleration
davrym
PostPosted: Fri Jun 01, 2012 3:36 am Up
My wife was driving the car 206 1.4 HDI and as she approached the traffic lights she lost acceleration. She pulled over and the engine was running but when she pressed the accelerator nothing happened, the engine would not rev. She stopped and started the car a minute or two later and it got her home. Now I had a service done last week and they said they had changed the fuel filter. I read a previous thread and I am wondering if this may have had an effect??
PostPosted: Sat Jun 02, 2012 1:24 am Up
What year, model, milage is the car?
davrym
PostPosted: Fri Mar 01, 2013 1:02 pm Up
Sorry I have not replied for so long but problem went away and never happened again until just recently. Thought it might have been trapped air in fuel line that had worked its way out.
It has cut out several times and the engine management light stays on. Just got it back from the garage and they said it reported a fault with the TPS (throttle positioning sensor). They then told me that they have cleared the fault code and I should drive it over the weekend to see if it still happens. If so they will replace the TPS. However they said I could bring it in Monday and they will replace the fuel filter if I want to see if that is the cause. Im not sure I should because I might be paying for something that does not need replacing. They did not fill me with confidence. The TPS will cost 100.00 pounds plus VAT plus labour.
206 1.4 HDI 2005
davrym
PostPosted: Fri Mar 01, 2013 1:03 pm Up
Sorry - mileage 56000
DREWDEN
PostPosted: Fri Mar 01, 2013 1:51 pm Up
Hi davrym, Had a similar problem a while ago, get your injectors checked out, mine went past the cutting out stage, went into limp mode, and engine was making a right noise, got it to garage and cost me £400 1 injector and three rockers had to be changed, said i was lucky it hadn't done more damage, my mileage was 60,000.
Don't wanna frighten ye, but ask him to check injectors.
OH mine had TPS fault.
206 2ltr Hdi glx 53 plate
davrym
PostPosted: Fri Mar 01, 2013 1:58 pm Up
Oouccchhh!! Thanks for the tip. I hope its not that bad. Engine sounds fine just the cutting out is the problem at moment.
DREWDEN
PostPosted: Fri Mar 01, 2013 2:15 pm Up
My engine was normal just before it went, was investigating the TPS fault at the time, just saying after it was repaired the TPS fault went. Think i have seen on here somewhere that the TPS very rarely go.
DREWDEN
PostPosted: Thu Mar 07, 2013 10:52 am Up
Hi Davrym
Just being curious if your problems been sorted, and what the garage said. Very Happy
