Posted: Thu Mar 07, 2013 6:03 pm |
anyone find me one of these, i dont know whether the gti 138 one would fit my 206 xs 1.6 16v, but i want an uprated mid range torque one, the 4-2-1, any help would be appreciated?
Posted: Thu Mar 07, 2013 6:17 pm |
gti will not fit the 1.6 depends how much you want to spend cause you can pick them up of eBay pretty cheap
Posted: Thu Mar 07, 2013 6:20 pm |
lukepug19 wrote: |
gti will not fit the 1.6 depends how much you want to spend cause you can pick them up of eBay pretty cheap |
can you send me a link to one that will fit please its a 2002, xsi 1.6 16v
Posted: Thu Mar 07, 2013 7:05 pm |
i bought one monday, arrived today and put it on, ill just find the link
| Iv had:
Now : GTi 180 again - Build thread | |
Posted: Thu Mar 07, 2013 7:06 pm |
| Iv had:
Posted: Thu Mar 07, 2013 7:11 pm |
thats for a 1.6 16v, in some of your posts on other threads you say you have a 1.6 8v?
| Iv had:
Posted: Fri Mar 08, 2013 6:23 am |
frenchfrog40 wrote: |
thats for a 1.6 16v, in some of your posts on other threads you say you have a 1.6 8v? |
yes mate just got the xsi the other day so ive got the straight through system but i need another 4-2-1 as the 8v doesnt fit,
Posted: Fri Mar 08, 2013 6:30 am |
http://www.ebay.co.uk/itm/PEUGEOT-206-1-4-1-6-16V-STAINLESS-STEEL-MANIFOLD-/230938479938?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D6085799418370717701%26pid%3D100015%26prg%3D1006%26rk%3D1%26sd%3D230938479938%26
thats the one i got. fitted great and sounds nice |
thanks mate, have u got the straight through exaust from the manifold, see much power or torque difference to it being standard? i did on my 8v when i had it fitted a lot midrange?
Posted: Fri Mar 08, 2013 7:36 am |
[quote="Adam2061994"]
thanks mate, have u got the straight through exaust from the manifold, see much power or torque difference to it being standard? i did on my 8v when i had it fitted a lot midrange?[/quote
what exhaust you using as im struggling to find one for my xsi, or was it a custom made?. anychance you could both put a video up so i can listen to what they sound like?
| 1.6 Xsi - Work in Progress!
"If it has wheels or a skirt, it's gonna give you problems." | |
Posted: Sat Mar 09, 2013 2:47 am |
that is the same manifold I have got fitted
Posted: Sat Mar 09, 2013 4:40 am |
lukepug19 wrote: |
that is the same manifold I have got fitted |
would you reccomend it? can you get a video up?
Posted: Sat Mar 09, 2013 5:15 am |
If you're serious then do Maniflow not do one?
Posted: Sun Mar 10, 2013 1:41 pm |
yeh, mine is straight through and as i have a sportex racing system, there is only 1 silencer which is the backbox, needless to say, the noise is quite amazing! it pops and bangs nicely, gives off a little pop when changing gear sometimes. good system. better throttle response. iv had a look at mine, i cant see well but i think its a 4-1 not a 4-2-1 (i didnt look before it got put on lol) however, its a good manifold.
| Iv had:
Posted: Sun Mar 10, 2013 3:03 pm |
will upload a video as soon as possible
Posted: Sun Mar 10, 2013 5:16 pm |
Cheers luke
