Latest: DanDan17
Overall: 17128
Online Now [306]:
Visitors: 305
Today: 65808
Total: 100666160
Forums › The Car › 206 Problems › HELP! 206 2.0 hdi split hose!
bri-man
PostPosted: Fri Mar 08, 2013 11:49 am Up
hi guys,
i have a hose split its the bottom hose that goes into the bulk head right next to the air filter pipe
im just wondering if anyone knows the part number thanks in advanced!!
PostPosted: Fri Mar 08, 2013 12:02 pm Up
Is it different to this?
PostPosted: Fri Mar 08, 2013 2:21 pm Up
send me your VIN
bri-man
PostPosted: Fri Mar 08, 2013 2:28 pm Up
It's the one below that Edward!! And ill inbox it you now mate
PostPosted: Fri Mar 08, 2013 2:51 pm Up
Is't the one circled in red?
bri-man
PostPosted: Fri Mar 08, 2013 4:44 pm Up
Can't really tell by the diagram mate! Can't see if it goes on to the bulk head or not, I believe it's a heater matrix hose?
bri-man
PostPosted: Sat Mar 09, 2013 12:03 pm Up
Sorted thanks!! Ended up improvising and using a similar hose off a fiesta
PostPosted: Sat Mar 09, 2013 2:02 pm Up
Glad that you got it all sorted Very Happy
