Posted: Fri Mar 08, 2013 12:49 pm |
hi guys,
i have a hose split its the bottom hose that goes into the bulk head right next to the air filter pipe
im just wondering if anyone knows the part number thanks in advanced!!
| | ![](images/spacer.gif) |
Posted: Fri Mar 08, 2013 1:02 pm |
Is it different to this?
![](http://i38.photobucket.com/albums/e105/s1pso/SDC18497.jpg~original)
Posted: Fri Mar 08, 2013 3:21 pm |
send me your VIN
Posted: Fri Mar 08, 2013 3:28 pm |
It's the one below that Edward!! And ill inbox it you now mate
Posted: Fri Mar 08, 2013 3:51 pm |
Is't the one circled in red?
![](http://i595.photobucket.com/albums/tt31/timon2210/hose_zpsed4ab216.jpg~original)
Posted: Fri Mar 08, 2013 5:44 pm |
Can't really tell by the diagram mate! Can't see if it goes on to the bulk head or not, I believe it's a heater matrix hose?
Posted: Sat Mar 09, 2013 1:03 pm |
Sorted thanks!! Ended up improvising and using a similar hose off a fiesta
Posted: Sat Mar 09, 2013 3:02 pm |
Glad that you got it all sorted ![Very Happy Very Happy](images/smiles/icon_biggrin.gif)
