Latest: DanDan17
Overall: 17128
Online Now [200]:
Visitors: 199
Today: 55325
Total: 100655688
Forums › The Car › 206 Problems › Star Torque bit size on Rear Hub Plate
A10PSW
PostPosted: Sat Mar 09, 2013 11:49 am Up
Anyone know what size Torque Bit I need to undo the x4 Star Torque bolts that hold the Rear Hub plate the the Axle Lower Arm?
PostPosted: Sat Mar 09, 2013 12:31 pm Up
Nope but I imagine it's one that every torx set has.
A10PSW
PostPosted: Sat Mar 09, 2013 12:44 pm Up
Nothing to do with the size of Torx Bit...
I am removing my rear axle at the moment ready for the new one to arrive.
I have managed to get one of the rear hubs off my car but I can not for the life of me get the the other side off!
I have even snapped a hub puller trying!
I have loosened the hand brake cable right off.
hit it with a hammer, but it just won't budge!
Any tips anyone?
