Forums › The Car › 206 Problems › developed a drivers rocking chair ? |
Posted: Sat Mar 09, 2013 1:00 pm |
as the title says in my gti the drivers seat as started to rock slightly when accelerating or braking, and the seat as a slight rocking motion when sliding it backwards and forwards ?
is it a simple case of remove seat and tighten everything up or are my runners on there last legs lol no pun intended there lol
Posted: Sat Mar 09, 2013 1:39 pm |
It's the runners...or it could be the mechanism that changes the height.
Posted: Sat Mar 09, 2013 3:34 pm |
ahh nuts
