Online Now [395]:
Visitors: 393
Members: 1
Today: 76857
Total: 156183989
Forums › The Car › 206 Problems › help i have no heating
minchgti
PostPosted: Mon Mar 11, 2013 4:05 pm Up
i have just got a gti and got it home and found out i have no heating, i have topped up the water and bleed it. the pipes going in and out of the heater matrix are hot but still no hot air out the vents, any ideas please?
PostPosted: Mon Mar 11, 2013 9:54 pm Up
Checked the pollen filter?
SinfulDesignCom
PostPosted: Mon Mar 11, 2013 10:12 pm Up
Worst case - leaky matrix. Hope not for the sake of your wallet. Keep an eye out for soggy carpets...
Bloody hell I am a pessimist =)
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
PostPosted: Tue Mar 12, 2013 4:19 am Up
Easy & cheap fix if it is Wink
GoogyWithers
PostPosted: Tue Mar 19, 2013 12:43 pm Up
I too have a leaky heater matrix, Im planning on putting K Seal in to sub due the leak for now until i can change the matrix. How difficult is it to change the heater matrix? I've done it on a golf Gti before and then was a mission hoping this should be easier.
GoogyWithers
Jeffers
PostPosted: Tue Mar 19, 2013 6:14 pm Up
Does it loose water ? Does the radiator get hot at all ?
Chris09smith
PostPosted: Fri Mar 29, 2013 1:51 pm Up
I too have a problem with the heating in my GTI180, ive checked all fuses and checked the fan under the dash. Today i had a mechanic test the fan, he said there was no power going to it, its possible it could be a relay. Does anyone know if this might be the case or would it be a similar issue and the heater matrix is screwed???
