Latest: tebas93089
Overall: 17179
Online Now [916]:
Visitors: 915
Today: 36426
Total: 137887768
Forums › The Car › 206 Problems › 1.4 oil leak
1.4 oil leak
Ciucur
PostPosted: Wed Feb 20, 2013 9:37 am Up
Hi all, my 05 1.4 started leaking oil onto my drive. It doesn't happen too often, from what I can figure out it seems to leak more as temperature (weather) goes down. It's not a lot but its definitely leaking. I got under the car this morning and manged to get a picture.
It doesn't seem to leak from the top half of the engine as there are no visible leak signs. Rolling Eyes When I got under the car, the sump was covered in oil.
Any advice on what to check to identify the origin of the leak?
Thanks in advance,
Chris.
PostPosted: Wed Feb 20, 2013 9:55 am Up
Is that the sump end of the oil filter attachment?
There's a couple of O ring seals located behind there.
bikesforme
PostPosted: Wed Feb 20, 2013 11:08 am Up
My leaks too i replaced the rocker cover gasket cured the top leak but bottom leak was still there. On replacing the timing belt saw the camshaft oil seal was leaking slightly , so replaced that.
Mine is still leaking so i need to take cambelt back off and replace the crankshaft oil seal too.
If yours is leaking drivers side bottom, good chance it could be these seals too.
black206
PostPosted: Tue Mar 12, 2013 3:21 pm Up
snap - our 2005 1.4 16v is leaking just the same, worse in the cold weather.
its in the garage tomorrow having the crankshaft seal changed (along with timing belt).
black206
PostPosted: Fri Mar 15, 2013 1:50 pm Up
its not the crankshaft.... but the head leaking oil externally. Seems to be a common thing with the gasket failing from looking on the net.
Black 2005 206 sport 1.4 16v
bridge9
PostPosted: Wed Apr 24, 2013 4:43 pm Up
hi guys mind if i butt in? mine is leaking too, it's a 2004 1.4 diesel. the leak seem to be from the back of the engine, above the starter but i can't bloody see for sure. it is leaking out on bolth sides underneath the car? any ideas??? ta
ps what milage should the belt be done??
