Online Now [352]:
Visitors: 351
Today: 110885
Total: 155713771
Forums › The Car › 206 Problems › coolant temp sensor
coolant temp sensor
Fifer
PostPosted: Mon Mar 11, 2013 9:28 am Up
Hi.
Can anyone confirm if the 1.4 hdi has 2 engine temp sensors. 1 to gauge and 1 to ecu or is it the single sensor located on the thermostat the supplies both?
1.4hdi 02
PostPosted: Tue Mar 12, 2013 6:04 pm Up
Bump. Anyone help this guy? MrBSI? Kris?
Fifer
PostPosted: Wed Mar 13, 2013 2:28 pm Up
Thanks for the post bump. Im pretty certain its only the one sensor on the thermostat but was certain I had read it used 2 for some bizzare reason. Im pretty certain my thermostat is dodgy (stuck open or sticking) so im goung to strip it off andhave a look/test at the weekend. I have seen a replacement that comes with a sensor so if it is ill change both.
1.4hdi 02
