Online Now [337]:
Visitors: 335
Members: 1
Today: 47734
Total: 157712423
Forums › The Car › 206 Talk › 206 1.6 16v xsi tuning?
Forum Index › 206 Talk
Adam2061994
PostPosted: Thu Mar 14, 2013 4:18 pm Up
anybody got a 206 xsi 1.6 16v, im looking at more power atm, so far it has a 4-2-1 stainsteel steel manifold and a straight decat race tube to a peco big bore backbox, anybody suggest any decent cams, or any good ecu tuning places, and could suggest anything else which could improve power/torque, any help will be grateful thankyou!
206 1.6 owner
colganraz
PostPosted: Thu Mar 14, 2013 5:20 pm Up
cams either newman or kent cams, check PUG1OFFs online shop, much difference in acceleration with the 421 manifold? considering one for mine at the minute
Former 206 XSi owner - Now 207 GT
www.206info.co.uk/Foru...56475.html
Zack
PostPosted: Fri Mar 15, 2013 4:55 am Up
Just a quick suggestion because you are running a de cat and will fail MOT I ran this cat when had stainless on old 206
www.ebay.co.uk/itm/906...1c20864523
Cheers
Zack
PostPosted: Fri Mar 15, 2013 4:57 am Up
Also if engine light is on run this on second sensor tricks the ECU.
www.ebay.co.uk/itm/90-...35b781d83f
If you know all this sorry.
cheers
RedHDI
PostPosted: Fri Mar 15, 2013 7:26 am Up
Turbo!! Bigger pistons, Fast Cams, gutted interior. There are alot of things to do. Maybe port and polishing or skim the head?
PezHdi
PostPosted: Fri Mar 15, 2013 7:40 am Up
All depends on how far you want to go and how much you want to spend.
EXL Pez
PostPosted: Fri Mar 15, 2013 8:08 am Up
Start with a bigger engine.
tsotd
PostPosted: Fri Mar 15, 2013 9:58 am Up
how much money you got? youve got cams/head work, throttle bodies or if your a fan of boost you can go the turbo/supercharger road. the only limit is how much youve got to spend
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
PostPosted: Fri Mar 15, 2013 10:51 am Up
How much money have you got?
If you don't want to go forced induction...
Exhaust, air filter will see to near nothing on their own
Cams + remap, port + polished throttle body will get between if 135hp - 150hp with a decent manifold and filter if setup correctly @ £450 - £600
Throttle bodies on standard pistons with the same cams will push 165hp @ £1500 - £2500 (possibly remain on standard ecu, but not recommended)
High compression setup including high comp pistons, forged con rods, uprated ARP bolts, headwork etc. Same throttle bodies as before but will need cams designed for aftermarket pistons. Will see 180hp - 195hp @ £4000 - £5000
Obviously prices differ majorly if you use brand new or second hand parts and if you do the work yourself but that's normally enough to put most people off. A lot of people think you will noticeable gains throwing a few quid here and there but it's far from the case.
Hint: If you want cheap(er) power just get a basic turbo setup for around £1500 (second hand) will see 180hp whilst still being fairly reliable on standard internals or more if you want to risk it.
colganraz
PostPosted: Sat Mar 16, 2013 4:01 am Up
why? the 1.6 has 27 bhp less than the 2.0 as standard and is a little lighter, much better on fuel, cheaper to tax and insure and the TU5 engine is really tuneable.
danlouiee
PostPosted: Sat Mar 16, 2013 5:10 am Up
I swear it's an jp4 engine?
colganraz
PostPosted: Sat Mar 16, 2013 5:14 am Up
TU5JP4
PostPosted: Sat Mar 16, 2013 8:49 am Up
JP4s are excellent to tune, even more so than the VTS / 106 GTI J4 due to the larger valves can easily see an extra 5-10bhp more with the same mods when mapped right
Jeffers
PostPosted: Sun Mar 17, 2013 7:35 pm Up
Cams would be a good start. All down to money really, plenty of stuff out there to buy
Adam2061994
PostPosted: Tue Mar 19, 2013 5:57 am Up
thanks for all your help! so my engine is very good to tune?
206 1.6 owner
