Online Now [1051]:
Visitors: 1050
Today: 243999
Total: 151368241
Forums › The Car › 206 Problems › OXYGEN SENSOR
OXYGEN SENSOR
jamiegti
PostPosted: Sat Mar 16, 2013 8:12 am Up
I have taken the car into the peugeot dealer to get a test done and they said that my oxygen sensor needed changing.. Today i have disconnected it and my car seams to be running fine, i am not going to drive my car like it is because i have been told it could break the CAT! While looking for this sensor i got told there was 2 of them(one before the CAT and one after it) i can only find 1 :S is it possible that the oxygen sensor after the CAT has been taken out as my exaust system is not the standard one? Thanks
PostPosted: Sat Mar 16, 2013 11:28 am Up
Have a look for two plugs down the back of the thermostat housing. There should be two idential plugs with a red part. One is green the other is blue. If they are both there then you have two sensors.
Is your chassis number coded RFN? Is so it should have two sensors.
PostPosted: Sat Mar 16, 2013 3:46 pm Up
do you have the EML light (Check engine) on the dashboard?
PostPosted: Sun Mar 17, 2013 4:55 am Up
A lambda sensor can fail and show no runnIng problems. Best to change it though.
Zack
PostPosted: Sun Mar 17, 2013 9:31 am Up
What size is the engine?
PostPosted: Sun Mar 17, 2013 11:11 am Up
Username suggests it a GTi.
jamiegti
PostPosted: Wed Mar 20, 2013 5:28 am Up
Hi, yes its a GTI and the code is RFR not RFN, i have been told some models only have one sensor before the CAT is this true?
PostPosted: Wed Mar 20, 2013 7:30 am Up
RFR cars only have one sensor.
