Online Now [323]:
Visitors: 322
Today: 125074
Total: 156231505
Forums › The Car › 206 Problems › 206 issue, any help really appreciated
harry206
PostPosted: Sat Mar 16, 2013 1:29 pm Up
Hello, long story... Yesterday i was driving at the end of a dual carriageway and there was a noise like the type when you run over the white lines in the road, there was a vibration and around 10 seconds after my car lost all power. I managed to slow down and pull into a farm where i sat for half an hour trying to fire up the car. The car would not go, after a phone call to my dad and a rescue tow home i really need some help to find the problem. I dont fancy paying huge fee's for someone to have a look at my car and then try and pull a fast one making me buy more and more things. My brother being a bus mechanic had a look and also changed the coil pack as this may have been the problem. But with a new one in today the problem still stays, it will not start. I will really appreciate any help on this for someone to point me in the right direction of what it could be, many thanks, Harry.
KrisB
PostPosted: Sat Mar 16, 2013 2:42 pm Up
Does it sound any different than when you usually try to start it?
I'd be looking more specifically at a cambelt failure or a hole somewhere in the engine.
French car specialist. West Sussex. www.KrisB.co.uk
PostPosted: Sat Mar 16, 2013 3:50 pm Up
What He Said I agree!
take the plastic cover that covers the cambelt,and take a look,and pray that it's not cut into half,because starting the car with no cambelt on,will make you more problems more than you think off,lots of work to be done if that is the case.
are there any lights on the dashboard as EML light?
harry206
PostPosted: Sun Mar 17, 2013 5:08 am Up
cambelts been checked and thank f**k its all in tack!:) there is a light that comes on every now and then and i noticed the airbag light flicked on for a second yesterday, brother reckons a dodgy earthlead or petrol filter, could that be the problem? many thanks!
Zack
PostPosted: Sun Mar 17, 2013 9:37 am Up
Put petrol direct in to engine see if is fires up if yea then something to do with fuels lines etc just a idea
DREWDEN
PostPosted: Sun Mar 17, 2013 10:48 am Up
Making a noise then cutting out, would logically tell me its the fuel pump.
Have it code read or see if fuel is getting to the injectors.
206 2ltr Hdi glx 53 plate
PostPosted: Sun Mar 17, 2013 2:15 pm Up
when you turn the ignition on,do you hear the sound of the fuel pump relay works or not?
harry206
PostPosted: Sun Mar 17, 2013 2:19 pm Up
its just like a whining noise when turning the ignition, nothing cuts out it just cut out the other day when travelling at 60 ish and didnt start... Brothers checked the cambelt and that seems fine, also checked that petrols getting through etc.. Hes getting a code tester onto it tomorrow so hopefully should find the problem:) cheers guys!
harry206
PostPosted: Mon Mar 18, 2013 2:04 pm Up
brothers narrowed it down to multiple cylinders misfiring, sais it can be something to do with the ignition? sounds scary and costly to me?
scotbrew
PostPosted: Tue Mar 19, 2013 10:32 am Up
got the same problem please let me know how you get on thanks
scotbrew
PostPosted: Wed Mar 20, 2013 4:35 pm Up
so did you fixed it?is't the coil pack?
