Latest: heikkisj
Overall: 17126
Online Now [140]:
Visitors: 139
Today: 13146
Total: 100385877
Forums › The Car › 206 Problems › top end camshaft
top end camshaft
stucowley
PostPosted: Mon Mar 18, 2013 2:52 pm Up
noticed a knocking on engine, diagnosed as a camshaft is knocking.
expensive to fix? easy to do?
cheers
PostPosted: Mon Mar 18, 2013 2:55 pm Up
Has it had the upgraded hydraulic tappets fitted?
PostPosted: Tue Mar 19, 2013 7:40 am Up
Just changed my sisters cam in her clio as it had split in the middle! One end had lifted and started to knock the cam cover.
PostPosted: Tue Mar 19, 2013 12:15 pm Up
That's not the camshaft!
stucowley
PostPosted: Tue Mar 19, 2013 3:31 pm Up
its all standard i think.
cheers
PostPosted: Tue Mar 19, 2013 3:36 pm Up
Pre April 2003 built EW10 engine's have known hydraulic tappet issues unless it's already had them replaced by the uprated part.
PostPosted: Wed Mar 20, 2013 3:33 pm Up
Well, I did no that, not sure what its called really, its connected to the valves. Thought someone might be interested to see it though!
Lecktorious
PostPosted: Wed Mar 20, 2013 4:32 pm Up
Trade Rating: +59
It's the crankshaft...
'98 Nile Blue 306 GTi 6
PostPosted: Wed Mar 20, 2013 4:40 pm Up
Thanks...don't think it is though.
PostPosted: Wed Mar 20, 2013 5:08 pm Up
Rofl hope you are joking Laughing
The complete unit is the rocker arms, the shaft possibly has another name not up on them really.
Lecktorious
PostPosted: Wed Mar 20, 2013 6:21 pm Up
Trade Rating: +59
DOH!!! bedtime for me.
PostPosted: Wed Mar 20, 2013 6:25 pm Up
What issues do they cause? and how can I find out if mine has the uprated or not? Bit worried now with mine being an 03 plate.
PostPosted: Wed Mar 20, 2013 7:16 pm Up
As Harry says, the broken price is the rocker, the cam is underneath.
