Posted: Tue Mar 19, 2013 9:49 am |
Are 180 Discs bigger than the gti 137 and can i still run my 137 callipers?
cheers
Posted: Tue Mar 19, 2013 9:52 am |
180 front discs are bigger then standard GTI discs.
NO, you need the matching calliper's for the discs.
Rear discs are the same.
Posted: Tue Mar 19, 2013 10:01 am |
Is it worth doing?
Cheers
Posted: Tue Mar 19, 2013 10:05 am |
Zack wrote: |
Is it worth doing?
If it was me id wait till my discs wanting replacing anyway then id do the upgrade.
Looking at the picture of your car I get the feeling you wont be able to wait
Posted: Tue Mar 19, 2013 10:15 am |
Nah im going to wait im running grooved and drilled all round at the mo. Feb 2014 when MOT runs out long time away car is coming off the and a lot is happening so im just getting loads of info together. Thanks for you help. One thing tho will i have to change my brake pipes?
Thanks again
Posted: Tue Mar 19, 2013 10:26 am |
Zack wrote: |
Thanks again |
I've just upgraded to 180 brake set up as I needed new discs and pads, they are pretty good and fill my 205 Speedlines lovely. You will need to have at least a 15inch wheel for them to fit! As long as you don't cut the brake lines they should just bolt straight on
| '02 206 Quiksilver. SP Kit. Gloss black 205 Speedlines. ICC Tuning WRC spoiler (civic style). Sparco Rally Flaps. Laguna splitter. Upper and lower front Struts. V-Maxx front coilovers and Apex rear shocks. GTI180 front Arb. GTI180 front brake set up. 4-2-1 Mani, 200cell sport cat, stainless pipes and sportex 3" rolled box. Gloss black morettes with yellow lenses. Yellow tinted fogs with yellow bulbs. | |
Posted: Tue Mar 19, 2013 10:33 am |
kobrakai1986 wrote: |
Zack wrote: |
Thanks again |
I've just upgraded to 180 brake set up as I needed new discs and pads, they are pretty good and fill my 205 Speedlines lovely. You will need to have at least a 15inch wheel for them to fit! As long as you don't cut the brake lines they should just bolt straight on |
Thank you for that im running 14 but going to 15x8.25J
