Latest: Andyblue64
Overall: 17123
Online Now [501]:
Visitors: 499
Members: 1
Today: 97765
Total: 98466461
Forums › The Car › 206 Problems › 206cc 2.0 wont rev properly and loosing power
chris_loader
PostPosted: Tue Mar 19, 2013 2:54 pm Up
yea when you mentioned the coil pack i had a quick look at prices and dam thats alot lol
206cc 2.0 16v
chris_loader
PostPosted: Tue Mar 19, 2013 2:59 pm Up
this problem could come from so many places
206cc 2.0 16v
PostPosted: Tue Mar 19, 2013 3:10 pm Up
Pay a professional to diagnose the problem.
This thread is turning in to a game of Guess Who.
OR you could just waste money repeatedly throwing parts at it till you sort it.
Choice is yours Whistle...
PostPosted: Tue Mar 19, 2013 3:30 pm Up
Edward wrote:
£102 for a coil pack from Euro Car Parts. Can get 25% discount on that though.
I have a working coil pack for sale if you need one to try.
Mr-Tigger
PostPosted: Tue Mar 19, 2013 4:41 pm Up
coilpack from stealership is £95 if u ask nicely Smile but as above,would imagine that would cause misfire too,or even OBD fault for one of the cyliners? when u say runs map,so its been remapped then? too ignore maf,lambda etc?
PostPosted: Tue Mar 19, 2013 4:43 pm Up
map = MAP sensor.
MAF = not fitted to EW10 engine.
ukskater01
PostPosted: Tue Mar 19, 2013 5:19 pm Up
I've found new coilpacks for £45 but that's with trade discount
Mr-Tigger
PostPosted: Tue Mar 19, 2013 5:38 pm Up
oooooh cheers edward lol Smile
chris_loader
PostPosted: Mon Mar 25, 2013 12:24 pm Up
a little update the problems has its bad days and they its worse days lol so i was looking at the coil pack and noticed that the wires to the plug the outer plastic casing had been worn away on 2 of the wires so i wraped some tape round them and tried to rev the engine but still no luck, would the wires touching cause damage to the coil pack,
i do need to find another coil pack to try and see if it is that,
as i kept driving the car i kept checking for codes and still nothing
206cc 2.0 16v
chris_loader
PostPosted: Mon Mar 25, 2013 12:26 pm Up
im guessing i must have the ew10 engine then
206cc 2.0 16v
chris_loader
PostPosted: Mon Mar 25, 2013 12:55 pm Up
one of the codes it has brought up before was about the air intake temp sensor which i have read can cause the anti pollen and cat fault and cause loss of power etc
206cc 2.0 16v
chris_loader
PostPosted: Mon Mar 25, 2013 1:02 pm Up
and read other people had problems with trottle body motors
206cc 2.0 16v
chris_loader
PostPosted: Mon Mar 25, 2013 1:05 pm Up
where is the air intake temp sensor as when i looked at the trottle body there are a few sensors on it
206cc 2.0 16v
PostPosted: Mon Mar 25, 2013 2:01 pm Up
It's a grey sensor on the throttle body that sits in the air flow. If you need one I've got one but I wouldnt think it would make a massive difference to the running of the engine. Every extra 10 degrees needs 3% more fuel so unless the sensor is telling the engine something stupid I wouldnt think it was at fault, If in doubt disconnect it and see what happens. It's a small player in running engines.
chris_loader
PostPosted: Tue Mar 26, 2013 4:02 am Up
Ohh right OK would the broken wires touching kill the coil pack
206cc 2.0 16v
Page 2 of 3
