Online Now [879]:
Visitors: 878
Today: 144595
Total: 154951288
Forums › The Car › 206 Problems › Car wont turn over or jump start or bounce start
Simmo
PostPosted: Tue Mar 19, 2013 6:45 pm Up
Im sorry if this is a repost, i already had a quick look around a few threads but couldn't find what i was looking for.
My car has been working great for a just under a week as it has just had its clutch replaced and just today i get in to start and not even a crank..... My mum jumped it and the car worked fine again for an hour until i drove it to the local shop turned it off and it wouldn't start again and it wouldn't even crank, except the battery works and seems to be fine, lights work, radio works, multimeter measure that the battery is working too...... but i wouldn't jump start again and we also tried bounce starting it but still nothing Sad any ideas?????
1.1 silver style www.206info.co.uk/Foru...52484.html
Jeffers
PostPosted: Tue Mar 19, 2013 6:47 pm Up
Loose earth on the gearbox ??
Simmo
PostPosted: Tue Mar 19, 2013 10:03 pm Up
been looking at videos on youtube and yeah some of them say something about the earthing of the starter motor
Jeffers
PostPosted: Wed Mar 20, 2013 6:02 am Up
does sound like an earth problem, could be either as youd have both off when changing a clutch
PostPosted: Wed Mar 20, 2013 7:23 am Up
Crank sensor is a usual problem when the clutch has been changed.
Simmo
PostPosted: Wed Mar 20, 2013 8:10 am Up
cheers for responses guys, clutch was replaced 5 days ago and is now back at the garage where it was fitted, I'm sure if it is the earth wire its most likely there fault which should result in no charges. So fingers crossed Smile
PostPosted: Wed Mar 20, 2013 2:19 pm Up
Yeh there's an earth wire attached to the gearbox which they took off to change the clutch.
