Posted: Mon Mar 18, 2013 2:52 pm |
noticed a knocking on engine, diagnosed as a camshaft is knocking.
expensive to fix? easy to do?
cheers
Posted: Mon Mar 18, 2013 2:55 pm |
Has it had the upgraded hydraulic tappets fitted?
Posted: Tue Mar 19, 2013 7:40 am |
Just changed my sisters cam in her clio as it had split in the middle! One end had lifted and started to knock the cam cover.
Posted: Tue Mar 19, 2013 12:15 pm |
That's not the camshaft!
Posted: Tue Mar 19, 2013 3:31 pm |
its all standard i think.
cheers
Posted: Tue Mar 19, 2013 3:36 pm |
Pre April 2003 built EW10 engine's have known hydraulic tappet issues unless it's already had them replaced by the uprated part.
Posted: Wed Mar 20, 2013 3:33 pm |
Edward wrote: |
That's not the camshaft! |
Well, I did no that, not sure what its called really, its connected to the valves. Thought someone might be interested to see it though!
Posted: Wed Mar 20, 2013 4:32 pm |
Trade Rating: +59
Steve206 wrote: |
Edward wrote: |
Well, I did no that, not sure what its called really, its connected to the valves. Thought someone might be interested to see it though! |
It's the crankshaft...
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Wed Mar 20, 2013 4:40 pm |
Thanks...don't think it is though.
Posted: Wed Mar 20, 2013 5:08 pm |
Lecktorious wrote: |
Steve206 wrote: |
Edward wrote: |
It's the crankshaft... |
Rofl hope you are joking
The complete unit is the rocker arms, the shaft possibly has another name not up on them really.
Posted: Wed Mar 20, 2013 6:21 pm |
Trade Rating: +59
Harry wrote: |
Steve206 wrote: |
Edward wrote: |
The complete unit is the rocker arms, the shaft possibly has another name not up on them really. |
bedtime for me.
Posted: Wed Mar 20, 2013 6:25 pm |
MrBSI wrote: |
Pre April 2003 built EW10 engine's have known hydraulic tappet issues unless it's already had them replaced by the uprated part. |
What issues do they cause? and how can I find out if mine has the uprated or not? Bit worried now with mine being an 03 plate.
Posted: Wed Mar 20, 2013 7:16 pm |
Harry wrote: |
Steve206 wrote: |
Edward wrote: |
bedtime for me. |
As Harry says, the broken price is the rocker, the cam is underneath.
