Latest: elelectricistadeMateo
Overall: 17127
Online Now [55]:
Visitors: 54
Today: 1288
Total: 100399525
Forums › The Car › 206 Problems › Peugeot 206 1.4 LX Questions
Speighty
PostPosted: Fri Mar 22, 2013 5:26 pm Up
My 206 has the problem of the cooling fan kicking in if the car reaches 90 degrees, i have been told the bearings have gone and it needs replacing, im just not 100% sure if i need just the fan or the whole unit, could someone point me in the right direction.
The next question is not really a problem, just want to know peoples views, i want to lower the car 40mm and my mechanic has advised to not even bother trying to lower the torsion bar on the existing axle and replace it with a refurbished one, is this a good idea or would you ask him to try and use the axle i have now.
Thanks for any help.
206gti_chris
PostPosted: Fri Mar 22, 2013 6:55 pm Up
the fan kicks in at 90 degrees to stop the car overheating that is normal,
if your planning on keeping the car for some time then lowering could be worth while, however sounds like it could be quite rusted if hes advisd to have a refurbished one, so it might be worth checking other vital areas of the car for signs of rust?
Speighty
PostPosted: Sat Mar 23, 2013 3:33 am Up
He serviced it yesterday and said most areas were fine, said he would try and use the existing one but would be easier to get a refurbished axle.
PostPosted: Sat Mar 23, 2013 2:47 pm Up
so the sound of your fans is loud,or there is squeaking sound ?if there is and u want to replace it,you need to replace the whole unit
Speighty
PostPosted: Sat Mar 23, 2013 11:41 pm Up
It's very loud when it does kick in, a new unit, cheers.
