Posted: Sat Mar 23, 2013 5:25 am |
hi all,
My steering has started to squeak when turning either direction when stationary or very slow speed. I had just had my wheels taken off / on after having them refurbished, I think this is when the problem started but unsure. It was alot louder when raining.. any thoughts?
thanks!
Posted: Sat Mar 23, 2013 9:24 am |
Aux belt slipping/squealing when demand is put on the PAS pump?
| Silvermetallic 2004 206 RC | |
Posted: Sat Mar 23, 2013 10:34 am |
Same noise when going over bumps, dont have to turn but even the slightest turn it squeaks. Could this still be issue with pump?
Posted: Sat Mar 23, 2013 12:45 pm |
karimali831 wrote: |
Same noise when going over bumps, dont have to turn but even the slightest turn it squeaks. Could this still be issue with pump? |
I'd say with that additional information I'd be looking at the suspension rather than steering pump/belt, but without hearing the actual noise it's hard to say... How long does the sound last? - a slipping belt can keep at it continuously, but something with a limited movement range will be limited in duration (though possibly repetitive...)
Posted: Sat Mar 23, 2013 7:09 pm |
The noise just stopped the next day, how strange..
Posted: Sun Mar 24, 2013 3:16 am |
Mine was doing this, up on ramps to check and on full lock it would squeak around the steering rack. Back on the ground it's stopped!
Posted: Fri Mar 29, 2013 5:51 pm |
Problem has returned, but now it is creaking so loudly it can be heard from inside! I got it checked and they said the ball joint needs replacing. I'm failing to understand how this joint perfectly in position can make a loud noise when turning, and it was changed last summer. Never had any loud creak from a ball joint.. but if this is case got no problem changing it AGAIN.
Posted: Sat Mar 30, 2013 4:22 am |
rubber top mount? they nock on bumps and creak when turning
| Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1) | |
Posted: Mon Apr 01, 2013 1:59 pm |
All of a sudden, it stopped again!! Really don't know what to make of this.. :S
It maybe occurs when something gets wet, keeping this in mind.
