Latest: heikkisj
Overall: 17126
Online Now [105]:
Visitors: 104
Today: 9307
Total: 100245626
Forums › The Car › 206 Problems › Steering squeaking?
Steering squeaking?
karimali831
PostPosted: Sat Mar 23, 2013 5:25 am Up
hi all,
My steering has started to squeak when turning either direction when stationary or very slow speed. I had just had my wheels taken off / on after having them refurbished, I think this is when the problem started but unsure. It was alot louder when raining.. any thoughts?
thanks!
206 GTI 180
mtempsch
PostPosted: Sat Mar 23, 2013 9:24 am Up
Aux belt slipping/squealing when demand is put on the PAS pump?
Silvermetallic 2004 206 RC
karimali831
PostPosted: Sat Mar 23, 2013 10:34 am Up
Same noise when going over bumps, dont have to turn but even the slightest turn it squeaks. Could this still be issue with pump?
206 GTI 180
mtempsch
PostPosted: Sat Mar 23, 2013 12:45 pm Up
I'd say with that additional information I'd be looking at the suspension rather than steering pump/belt, but without hearing the actual noise it's hard to say... How long does the sound last? - a slipping belt can keep at it continuously, but something with a limited movement range will be limited in duration (though possibly repetitive...)
karimali831
PostPosted: Sat Mar 23, 2013 7:09 pm Up
The noise just stopped the next day, how strange.. Surprised
206 GTI 180
PostPosted: Sun Mar 24, 2013 3:16 am Up
Mine was doing this, up on ramps to check and on full lock it would squeak around the steering rack. Back on the ground it's stopped!
karimali831
PostPosted: Fri Mar 29, 2013 5:51 pm Up
Problem has returned, but now it is creaking so loudly it can be heard from inside! I got it checked and they said the ball joint needs replacing. I'm failing to understand how this joint perfectly in position can make a loud noise when turning, and it was changed last summer. Never had any loud creak from a ball joint.. but if this is case got no problem changing it AGAIN.
206 GTI 180
tsotd
PostPosted: Sat Mar 30, 2013 4:22 am Up
rubber top mount? they nock on bumps and creak when turning
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
karimali831
PostPosted: Mon Apr 01, 2013 1:59 pm Up
All of a sudden, it stopped again!! Really don't know what to make of this.. :S
It maybe occurs when something gets wet, keeping this in mind.
206 GTI 180
