Latest: sparrowdclxvi
Overall: 17139
Online Now [173]:
Visitors: 172
Today: 15037
Total: 112699082
Forums › The Car › 206 Problems › deleted
deleted
Quikrex
PostPosted: Tue Mar 26, 2013 6:04 am Up
deleted
Andy180
PostPosted: Tue Mar 26, 2013 1:10 pm Up
Oil leak will be the oil filter housing you will need a new seal from pug there only a couple of quid, as for the knocking possibly engine mounts or maybe driveshafts both worth a look.
GTI 180
Lewis
PostPosted: Tue Mar 26, 2013 2:08 pm Up
mine used to leak from there, never solved it but did here after i part ex'd that its the housing seal as above .. sorry to be so helpful Laughing
Tivoli LX 1.1
Black GTI 180
White VXR Burg
gpvecchi
PostPosted: Tue Mar 26, 2013 3:32 pm Up
I changed the OR in mine. It was ok for about a month, then it started leaking again...
Now, recently my car started to make a noise like that on RH side; it does it even on some bumps. I have new arms, antiroll links, steering "I don't know the word, the thing that connects steering to yoke" and a new set for top mount, all genuine one.
My sound is like a clicking noise, you can reproduce it trying to start with lifted handbrake...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
PostPosted: Tue Mar 26, 2013 4:30 pm Up
The plastic clip that holds the PAS pipe under the sump needs fixing...
Also what on earth are those orange wires under the front crossmember for?
Quikrex
PostPosted: Tue Mar 26, 2013 7:11 pm Up
deleted
Quikrex
PostPosted: Wed Mar 27, 2013 5:18 am Up
deleted
Quikrex
deleted
Quikrex
PostPosted: Fri Mar 29, 2013 2:04 pm Up
deleted
Quikrex
PostPosted: Tue Apr 02, 2013 11:22 am Up
deleted
PostPosted: Tue Apr 02, 2013 11:43 am Up
Could be interesting to see how it runs after the belt has been removed!
Quikrex
PostPosted: Tue Apr 02, 2013 12:14 pm Up
deleted
