Latest: Andyblue64
Overall: 17123
Online Now [309]:
Visitors: 308
Today: 65739
Total: 98434462
Forums › The Car › 206 Problems › Coil Pack Bolts
Coil Pack Bolts
meas14
PostPosted: Mon Mar 25, 2013 7:46 am Up
Hello,
Changed over my coil pack again, but this time the bolts decided to snap after 1 turn.....
Anyone know where I can pick up some new ones?
Cheers
Pug 206 GTI and Classic Mini Mayfair Owner
PostPosted: Mon Mar 25, 2013 7:47 am Up
main dealer, only a couple of £ if that.
DanT
PostPosted: Mon Mar 25, 2013 1:20 pm Up
Peugeot, or scrapyard if you're desperate (Obviously used though). Probably ebay too?
LORDPSK
PostPosted: Tue Mar 26, 2013 3:42 pm Up
B & Q They are normal 10mm bolts or as I have scene stud iron with nuts and washers on
Peugeot 206
PostPosted: Tue Mar 26, 2013 4:18 pm Up
Do not buy them from B&Q!
LORDPSK
PostPosted: Tue Mar 26, 2013 4:54 pm Up
why
Peugeot 206
PostPosted: Wed Mar 27, 2013 3:18 am Up
Unlikely to be the right length, grade and thread type.
