Online Now [617]:
Visitors: 616
Today: 129710
Total: 155424992
Forums › The Car › 206 Talk › Bosch Super 4 Part Number - GTi180
Forum Index › 206 Talk
Uz
PostPosted: Wed Mar 27, 2013 2:18 pm Up
I've got a set of brand new Bosch Super 4 spark plugs from when I had the XSi and was wondering if the spark plugs are the same as the ones that are in the 180s..?
I've noticed the part numbers are the same as the XSI and GTi engines. Which is why I'm wondering if they'll work on the 180.
Ideally a part number from a 180 set so I can match them up with the XSi set would be great.
If anyone has this, please let me know Smile
PostPosted: Wed Mar 27, 2013 2:25 pm Up
Bosch doesn't list a Super 4 spark plug for the GTI 180 engine.
Uz
PostPosted: Wed Mar 27, 2013 2:28 pm Up
In that case, what are the recommended spark plugs to use in the GTI 180..? I've noticed they do an Iridium spark plug, but would like some input on this.
PostPosted: Wed Mar 27, 2013 2:31 pm Up
Bosch FQR7ME is the only plug Bosch recommend.
Bosch part number is 0 242 235 791
0.90mm for the gap.
Uz
PostPosted: Wed Mar 27, 2013 2:32 pm Up
Apparently, Bosch do do (yes I said do do) a Super 4 Spark Plug for the 180... found this pic on another thread.
PostPosted: Wed Mar 27, 2013 2:34 pm Up
Go for it then, you know better then Bosch technical Wink
HDI90
PostPosted: Wed Mar 27, 2013 2:50 pm Up
thats correct uz, 522 is what i used in my old 180. email them they will tell you its correct as i did the same
GTI 180
Uz
PostPosted: Wed Mar 27, 2013 3:01 pm Up
Thanks mate... I'm pretty sure the XSi is 522 as well. If it is, I've just saved my self 20 odd quid which I can use on other bits for the service.
HDI90
PostPosted: Wed Mar 27, 2013 3:22 pm Up
Yes the 1.6 16v and both gti and 180 use the same plugs, for some strange reason bosch dont list them on there tech sheets
GTI 180
Uz
PostPosted: Wed Mar 27, 2013 3:36 pm Up
Just found the set I had from my XSi and match the part numbers off the picture and the spark plugs themselves and they match. Nice little saving. Happy days when I picked them up from Halfords for £5 due to clearance (old packaging).
