Online Now [274]:
Visitors: 274
Today: 26697
Total: 156546942
Forums › The Car › 206 Problems › Drivers Door Interior Light Switch
Speighty
PostPosted: Thu Mar 28, 2013 10:11 am Up
Since i have owned the car, about 2 year opening the drivers door has never turned the courtesy light on, passenger side does and if i remove the key from the ignition the light comes on.
I also dont get a warning sound if the lights have been left on, this has caused a few flat batteries, i know the switch is built into the lock.
What are my options, a new lock or could the wiring be at fault, the electric window works fine.
Cheers for any help.
PostPosted: Fri Mar 29, 2013 1:31 pm Up
The 'door closed' switch is built-in to the lock unit (latch/solenoid etc) of the door as you say so replace lock.
The lights warning comes from a buzzer in the BSI.
It only comes-on when you open driver's door I think (same as keys left in ignition barell warning) so it would make sense.
Speighty
PostPosted: Fri Mar 29, 2013 5:49 pm Up
I don't get a warning if I leave the keys in the barrel either, the problem could be more than just the door lock, might just leave it.
In regards to changing the door lock, is it just a matter of replacing the lock unit, I wouldn't need to change the exterior door lock, I can still use the key I have now, if so I can try and get a unit from a scrap yard.
