Posted: Thu Mar 28, 2013 2:13 pm |
hi guys. some random theif decided to screw driver my lock. now the central locking locks and unlockd straight away. can i just remove the lock or does it need replacing any help will be fantastic cheers
Posted: Fri Mar 29, 2013 1:42 am |
he must have damaged the central locking somehow as the lock barrel can be removed as people smooth is with no issues
Posted: Fri Mar 29, 2013 5:01 am |
could be the actuator? Just buy a cap off ebay to go over the barrel. If you replace the locks you will need to replace all of them.
Posted: Fri Mar 29, 2013 5:19 am |
I will be getting rid of mine but need the key still so probably no good all electric side of it will be going. I think the solenoid gone on the pass side but I'll be Getting a new door with all that in
Posted: Fri Mar 29, 2013 10:39 am |
No, there is a small coupling 'wire' from the lock barell to the locking mechanism (which includes door-switch, solenoid, latch etc).
I recon he's jammed that link and the mechanism thinks a key is in there and turned CCW.
Would be surprised if the lock unit itself is damaged.
You can get replacement barell (+ 1 free blade) which matches to the VIN from main dealers, if you provide them with id and around 40 EUR.
Posted: Fri Mar 29, 2013 11:08 am |
I'll be the first to say what a b*****d
Posted: Fri Mar 29, 2013 12:59 pm |
thanks guys, ive just capped the barrel, after looking at each mechanism it looks like its got something to do with the boot central locking as nothing happens when i press the key, the other locking mech works but its dud from the boot,
any idea how much in would cost?
