Online Now [573]:
Visitors: 573
Today: 197305
Total: 151970620
Forums › The Car › Request a how-to › hand brake adjustment
johnsom
PostPosted: Fri Mar 29, 2013 1:41 pm Reply with quote Up
hi all
can anybody give me the full procuder on how to replace and adjust the rear handbrake on a 2002 20 6 1.4 hdi drums
thanks
Moved into the Request a How to section - Tolkienfan001
PostPosted: Fri Mar 29, 2013 2:13 pm Reply with quote Up
It should have auto adjusters inside the drums. these are prone to going and need the drums removing to replace them.
Normally to adjust the number of clicks on the handbrake, you remove the trim from between the seats (1 torx screw) and then there is the adjuster nut. just tighten it to the desired level, not to tight though as your brakes will bind when driving.
If the cables are stretched and need replacing, it's drums off and centre trim off and you should be able to work it out from there. If you can't, then you really shouldn't be doing the job in the first place.
  Quick Reply
Username:
Message:
Quote the last message
