Latest: dreyfalon
Overall: 17121
Online Now [556]:
Visitors: 555
Today: 136377
Total: 97662622
Forums › The Car › 206 Problems › Low mileage 206 gti problems
Markco79
PostPosted: Sun Apr 07, 2013 3:13 am Up
Just bought a 54 plate 206 gti (138) with 27k genuine miles. Car is spotless, however gearbox feels sloppy and wooden and pulling away in first it feels like clutch is slipping. You then go into 2nd and it feels like it clunks into gear. All other gears are fine and it managed a 300 mile home on m1/a1 yesterday with no issues.
Any advice on what could be wrong? Clutch knack erred, clutch cable or even worse box is goosed. Strange for it to go wrong at 27k
PostPosted: Sun Apr 07, 2013 3:51 am Up
If clutch is slipping, get it changed.
The clunky gearbox seems normal, but it depends what you're comparing it to.
PostPosted: Sun Apr 07, 2013 4:29 am Up
Mine has a knackered bottom engine mount causing a clunky gearbox
tsotd
PostPosted: Sun Apr 07, 2013 5:00 am Up
change the clutch (seems to be a common problem), gearbox oil (dont reuse the old stuff), lower engine mount and gear linkage.
should make it feel better
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
