Online Now [444]:
Visitors: 443
Today: 102390
Total: 154913842
Forums › The Car › 206 Problems › rear axle question.
rear axle question.
14hdi
PostPosted: Mon Apr 08, 2013 2:42 am Up
If (in a dream world when it's not all rusty) you unbolted the torsion bar removed the off centered washer, leaving the rest of the beam assembled would the torsion bar slide through the radius arm without removing the radius arm ?
Or is the best way to move the torsion bar to remove the hole radius arm then hammer/slide hammer the bar out ?
PostPosted: Mon Apr 08, 2013 3:55 am Up
Leave the arms on the car at all costs.
14hdi
PostPosted: Mon Apr 08, 2013 4:05 am Up
Replacing bearings. Just thinking of the best way to assemble it to the correct high once I've put.my "dummy" shocks in.
14hdi
PostPosted: Mon Apr 08, 2013 4:14 pm Up
Managed to get the axle apart, had it so hot there are pools of metal in some areas.
And after dismantling the axle i fully understand how it all works. Thus answering my initial question.
14hdi
PostPosted: Wed May 01, 2013 2:54 am Up
